P25 Trunking
rickn6pe
P25 Trunking
Postby rickn6pe » Mon Feb 27, 2017 4:18 pm
How can I used SDRPlay 1 to receive trunked signals? It does not work with Unitrunker.
Rick N6PE
CaptainNemo
Re: P25 Trunking
Postby CaptainNemo » Fri Mar 10, 2017 7:24 pm
You can try with DSD+ (aka dsdplus).
You need the following "set-up" (in synth): a front end software supporting sdrplay (e.g. sdr#) --> vb-cable --> dsd+
(btw: unfortunately sdr# do not support completely sdrplay, so, for example you cannot use useful sdr# plugin like "dsd+ plugin"
nevertheless you can run it by hands...)
Last "general available" version is DSD+ 1.101 (is what I'm using currently)
As far as I know this version supports: NXDN48/96, DMR, MotoTRBO, APCO P25 ph1, X2-TDMA, ProVoice, D-Star (no audio), dPMR(no audio)
The "general available" (= downloadable) version is rather "old". There is a newer version deployed as "fastlane"
(means you pay few dollars and they give you a link to download -- more ore less -- I never tried...).
Hope it helps.
Bye
Gio
CaptainNemo
Re: P25 Trunking
Postby CaptainNemo » Sat Mar 11, 2017 4:40 pm
I forgot to say... if you use the "old" sdr# build 1361 (+ sdrplay device controller 3.8.3) you can
use the DSD interface plugin for sdr#.
bye
gio
