HDSDR w/RSP2 to HRD to a FTDX3000
W0EOD
Postby W0EOD » Thu Mar 02, 2017 3:19 am
Ok I am in need of little help here, I have my FTDX3000 hooked to my pc via USB, and HRD has always worked just fine, Now I connected my RSP2 and got HDSDR working just fine with the FTDX3000 via Omnirig. HRD is not running at this time.
The issue I am having is getting HDSDR to connect to HRD via DDE to Hrd. I am starting up the 3000, then HRD v6.3, then starting up HDSDR, I go to the HDSDR option, select DDE to HRD and everytime it says failed to connect :(
Am I missing a setting somewhere? Maybe something in Hrd's settings that's not turned on?
W0EOD
Re: HDSDR w/RSP2 to HRD to a FTDX3000
Postby W0EOD » Tue Mar 07, 2017 3:45 pm
Still needing some info on getting this working, HDSDR will not connect to HRD via DDE to HRD setting..
Harry
Postby Harry » Wed Mar 08, 2017 1:05 pm
Not sure why you are using DDE. I'm running HDSDR with HRD, SDRplay and my TS-990 using OmniRig and all works just fine. Everything synchs just fine.
W0EOD
Postby W0EOD » Thu Mar 09, 2017 4:47 pm
Harry I am going to assume the 990 has a little bit different interface then the dx3000, how are you getting all 3 to share that same com port? Are you using a Shared serial port software? The reason you use DDe to Hrd is Hrd runs its DDE server at start up and this avoids the com port conflicts.
Users browsing this forum: cathalferris and 10 guests
