SDR Play & HDSDR
Cheemag
SDR Play & HDSDR
Postby Cheemag » Tue Apr 04, 2017 12:47 pm
GA OMs,
I am using the CCW SDR4+ with HDSDR and find that either HDSDR or the SDR4+ is failing to tune the
receiver after coming up from minimize on a recording schedule activation. The tuned frequency is
whatever was last used although the freq readout gives the new frequency. Changing the frequency
makes no difference, the VFO just won't tune until HDSDR is closed and run again. Then you have to
put the new freq in manually .... }o:
Does anyone know if the SDRplay would overcome this problem if used with HDSDR ?
Regards,
Jim
mikexeno
Re: SDR Play & HDSDR
Postby mikexeno » Fri Apr 28, 2017 8:10 pm
1 I would download the latest version of HDSDR
2 I would reset HDSDR completly
3 I would look for the latest EXT/IO from cross county wireless.
4 Keep in mine this is a Soundcard based SDR with a built in soundcard. You have reduced bandwidth vs the RSP. Make sure your selecting the proper options in the recorder.
5 1 SDR with not fix the others issues when it comes to the frontend0. You have 3 variables here in the Frontend 1 the version- 2- The bandwidth recorded and 3 your computer.
