Don't find SRP1
darwenn
Don't find SRP1
Postby darwenn » Sat Sep 16, 2017 5:02 pm
Hello, i can"t parameter my SRP1 Sdr Device under Cubic. I think is not found (but work perfectly on windows) and USB PORT IS correct.
I 'am under ubunto 16.04
What is the problem ? I have No Device identification datas.
jm62@jm62:~$ SoapySDRUtil --check=sdrplay
Loading modules... done
Checking driver 'sdrplay'... PRESENT
jm62@jm62:~$ SoapySDRUtil --probe=sdrplay
Probe device sdrplay
-- Device identification
driver=null
hardware=null
-- Peripheral summary
Channels: 0 Rx, 0 Tx
Timestamps: NO
darwenn
Re: Don't find SRP1
Postby darwenn » Sat Sep 16, 2017 6:33 pm
For information, the SDR have no name :
jm62@jm62:~$ lsusb
Bus 002 Device 004: ID 0bc2:5020 Seagate RSS LLC FreeAgent GoFlex
Bus 002 Device 005: ID 1df7:2500 <- here is the SRP1 receiver
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 005: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 004: ID 734c:5925 TBS Technologies China
Bus 001 Device 003: ID 046d:c52f Logitech, Inc. Unifying Receiver
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Re: Don't find SRP1
Postby sdrplay » Sun Sep 17, 2017 7:47 am
The report above shows that SoapySDRPlay library hasn't been built/installed.
You will find build instructions here: https://github.com/pothosware/SoapySDRPlay/wiki
darwenn
Re: Don't find SRP1
Postby darwenn » Sun Sep 17, 2017 8:45 am
Thanks for your answer, but i do that.
This is all i do on a new and clean ubuntu installation
1 Connect the SRP1 Receiver on a USB 2.0 Port
2 Download and execute RUN FILE : The API/Hardware Driver – version 2.10.2 : no errors
3
sudo apt-get install \
cmake g++ \
libpython-dev python-numpy swig
4 Download and Build SoapySDR (No errors building)
git clone https://github.com/pothosware/SoapySDR.git
cd SoapySDR
mkdir build
cd build
cmake ../
make -j4
sudo make install
sudo ldconfig
5 Download and build SoapySDRPlay (no errors building)
git clone https://github.com/pothosware/SoapySDRPlay.git
cd SoapySDRPlay
mkdir build
cd build
cmake ../
make
sudo make install
6 Verify if it's ok
7 Verify parameters (It seem not recognized)
Probe device
driver=null
hardware=null
Timestamps: NO
8 Verify USB NAME (The device has no name ! I think it's not correct, but why ?)
jm62@jm62:~$ lsusb
Bus 002 Device 009: ID 1df7:2500 <- NO NAME RECOGNIZED
I think i do all is correct installation, but why the device not display ? And why no name in USB LIST ? I don't understand. Please help.
Re: Don't find SRP1
Postby sdrplay » Mon Sep 18, 2017 5:52 am
Maybe you need sudo ldconfig after the SoapySDRPlay as well?
If you run SoapySDRUtil --info and it says null driver then it means SoapySDRPlay library hasn't been installed correctly. It goes into the /usr/local/lib/SoapySDR/modules0.6 (or similar) directory. So you can check if it's in there.
SoapySDRUtil --probe=sdrplay specifically checks for RSPs
