SdrSharp High Z input?
I managed to get my RSP2 running with SDRSharp 1500, but is there a way to select the High Z Input or the Bias-T? If there is a way please tell me how to do it.
Re: SdrSharp High Z input?
Hi there
I am no longer using SDRSharp for HF using my RSP2 and revision 1360 and am now simply using a RTL SDR for V/UHF scanning, however with that revision at least one could access the RSP radio control panel and in my case being presented with a default antenna selection of Port A in what appears as a "drop-down" selector.
My experience was that the "drop-down" menu had to be scrolled (somewhat erratically using the mouse wheel, when it became possible to select Port B or the Hi-Z Port.
Personally, I find that SDRuno is so fully featured for HF reception that I could see no merit in pursuing this with SDRSharp, whilst it's current lack of a scanning feature is regrettable, it will doubtless be addressed in time.
