Gr-osmoSDR don t found SDRplay under windows.
Hello
I would like to test SRP1 under gnuradio on windows. It's work perfectly under linux but under windows i think OsmoSDR don't found my SRP1 device. The drivers are installed and that work perfectly with HDSDR OR SDRUNO.
When i launch the GRC radio TM testing with SDRPLAY on windows 10 64bits (it's ok with linux) i have :
gr-osmosdr c653754d (0.1.5git) gnuradio 3.7.11.1
built-in source types: file osmosdr fcd rtl rtl_tcp uhd hackrf bladerf airspy redpitaya
FATAL: No supported devices found to pick from.
What can i do ? I think it's impossible to recompile grosmosdr under windows. The Same GRC working under Ubunto. I don't understand.
Please help.
Please help.
Re: Gr-osmoSDR don t found SDRplay under windows.
We support SoapySDR library, so you'll need to get gr-osmosdr build that supports SoapySDR. Not sure where that would be for Windows but it does exist for Linux, etc.
I'm not sure if it does exist for windows, I can't find it.sdrplay wrote:Not sure where that would be for Windows but it does exist for Linux, etc.
The best testosterone boosters money can buy!
