Error compiling CubicSDR on Ubuntu 14.04
davem734
Postby davem734 » Mon Oct 16, 2017 12:35 am
Any help would be appreciated:
[ 67%] Building CXX object CMakeFiles/CubicSDR.dir/src/visual/ImagePanel.cpp.o
/home/gmcmh/Apps/CubicSDR/src/visual/ImagePanel.cpp:13:6: warning: unused parameter ‘evt’ [-Wunused-parameter]
 void ImagePanel::paintEvent(wxPaintEvent & evt) {
[ 68%] Building CXX object CMakeFiles/CubicSDR.dir/src/process/VisualProcessor.cpp.o
[ 70%] Building CXX object CMakeFiles/CubicSDR.dir/src/process/ScopeVisualProcessor.cpp.o
In file included from /home/gmcmh/Apps/CubicSDR/src/process/ScopeVisualProcessor.h:6:0,
                 from /home/gmcmh/Apps/CubicSDR/src/process/ScopeVisualProcessor.cpp:4:
/home/gmcmh/Apps/CubicSDR/src/process/VisualProcessor.h: In constructor ‘VisualProcessor<AudioThreadInput, ScopeRenderData>::VisualProcessor()’:
/home/gmcmh/Apps/CubicSDR/src/process/VisualProcessor.h:14:7: error: conversion from ‘std::nullptr_t’ to non-scalar type ‘VisualProcessor<AudioThreadInput, ScopeRenderData>::VisualInputQueueTypePtr {aka std::shared_ptr<ThreadBlockingQueue<std::shared_ptr<AudioThreadInput> > >}’ requested
 class VisualProcessor {
/home/gmcmh/Apps/CubicSDR/src/process/ScopeVisualProcessor.cpp: In constructor ‘ScopeVisualProcessor::ScopeVisualProcessor()’:
/home/gmcmh/Apps/CubicSDR/src/process/ScopeVisualProcessor.cpp:8:90: note: synthesized method ‘VisualProcessor<AudioThreadInput, ScopeRenderData>::VisualProcessor()’ first required here
 ScopeVisualProcessor::ScopeVisualProcessor(): outputBuffers("ScopeVisualProcessorBuffers") {
make[2]: *** [CMakeFiles/CubicSDR.dir/src/process/ScopeVisualProcessor.cpp.o] Error 1
make[1]: *** [CMakeFiles/CubicSDR.dir/all] Error 2
make: *** [all] Error 2
davem734
Re: Error compiling CubicSDR on Ubuntu 14.04
Postby davem734 » Thu Oct 19, 2017 2:20 am
