Orbital Satellite HRPT Image Reception
RSP2user
Re: Orbital Satellite HRPT Image Reception
Post by RSP2user » Sun May 27, 2018 12:37 am
An additional post of interest is the HRIT and LRIT Low-Cost System: https://www.sdrplay.com/community/viewt ... f=5&t=3262
RSP2user
Post by RSP2user » Sun May 27, 2018 10:18 pm
In case anyone was wondering how well the NooElec SAWBird GOES LNA/Filter combined with the Premiertek 1m grid antenna described in the HRIT and LRIT Low-Cost System ( https://www.sdrplay.com/community/viewt ... f=5&t=3262 ) works for HRPT, here is an initial test showing the signal level from a NOAA 18 pass as well as a manually-tracked image showing subtropical storm Alberto from NOAA 19 with a 31 degree maximum altitude pass. WIth optimized antenna tracking, results are expected to be better.
Noaa 18 NooElec SAWBird LNA and 1m PremierTek Grid.JPG (162.47 KiB) Viewed 15173 times
NOAA_19_HRPT_20180527_211230 LR v2.jpg (206.57 KiB) Viewed 15173 times
RSP2user
Post by RSP2user » Sat Jun 02, 2018 10:09 pm
Better 60 degree maximum altitude hand tracked NOAA 19 HRPT pass using the Premiertek ANT-GRID-24DBI antenna and the NooElec SAWBird GOES LNA.
NOAA_19_HRPT_20180602_214244-rgb-corrected v2.JPG (184.06 KiB) Viewed 15127 times
RSP2user
Post by RSP2user » Fri Dec 28, 2018 5:32 pm
USA-Satcom has recently updated the XHRPT Decoder software to include MetOpC. The range of orbital HRPT imaging satellites covered by the XHRPT software is now:
NOAA15
NOAA18
NOAA19
Meteor-MN2
Fengyun-3A
Fengyun-3B
Fengyun-3C
MetOpA
MetOpB
MetOpC
