SDRPlay with SDRConsole problem
Ronvw
Post by Ronvw » Sun Oct 18, 2015 9:21 pm
Hello I am a new SDRPlay user. I was successful in getting it up and running with HDSDR. Today I was trying to get it running with SDRConsole. I am getting a "can't start because mfc100u.dll is missing" message. I did a search and it says that Microsoft Visual C++ must be installed. I have multiple versions installed including 2010.
Any help would be appreciated.
Ronvw
Re: SDRPlay with SDRConsole problem
Post by sdrplay » Sun Oct 18, 2015 11:14 pm
Hi Ronvw,
Have you tried this, it's from sdr-radio.com/support...
"The kits require the VS2010 C++ redistributable, this is installed on your system and can be found in the SDR-Radio.com entry of the Windows Start Menu."
jazzkutya
Post by jazzkutya » Mon Oct 19, 2015 2:08 am
That's interesting, I only got this problem when I installed it on linux with wine. If this is your case use winetricks to install mfc.
http://wiki.winehq.org/winetricks
then after you downloaded winetricks do:
./winetricks vcrun2010
if you are not using wine but windows then unfortunately i can't help, it installed fine for me with the visual c runtime included in the sdrconsole installer.
micked
Post by micked » Mon Oct 19, 2015 6:33 am
Try to put mfc100u.dll in your system32 folder, atatched the dll from my system that works fine with SDRconsole.
http://www.filedropper.com/mfc100u
Ronvw
Post by Ronvw » Mon Oct 19, 2015 10:51 pm
Thanks to everyone,
The problem was that I was running 64 bit windows but the C++ redistribution package was 32 bit. I found and installed the correct 64 bit package and everything is working great. I really like SDRConsole and the new version it is even better.
Great forum appreciate everyone's help.
Ronvw
markorvan
Post by markorvan » Fri Apr 15, 2016 8:42 am
Ronvw wrote:Hello I am a new SDRPlay user. I was successful in getting it up and running with HDSDR. Today I was trying to get it running with SDRConsole. I am getting a "can't start because mfc100u.dll is missing" message. I did a search and it says that Microsoft Visual C++ must be installed. I have multiple versions installed including 2010.
Ronvw
I know what you need. You need to remove this error, and simply replacement of this file could not help you, so you might need to try another way, like fixed tool, which you can find here: http://fix4dll.com/mfc100u_dll
