Lowest frequency
Lowest frequency
Jon, I seriously suggest that you rethink the claimed 100 kHz start frequency of SDRplay. I would suggest 45 kHz to be a fair assessment. I can decode the strong MSF on 60 kHz and there is another signal, present on both the SDRplay, my 24 bit sound card and my WinRadio G33DDC at 45 kHz. No-one appreciates blagging (and this niche has got one already) but you would be perfectly accepted to claim a 50 kHz start.
Re: Lowest frequency
Grimeton will transmit next Saturady 24 oct on 17.2Khz, will try and listen in on that with the SDRplay, will be interesting!!
17.2 kHz will be too low for SDRplay. However, you can simply use your PC sound card for that.
Yeah, I know anout rx directly on my soundcard with the SAQrx program, but I live quite close (150km) from Grimeton so I will try anyway
I tried VLF reception without a converter today. My SDRplay works down to approx 24 kHz. DHO38 (23,4 kHz) is the lowest station i can identify between lots of mirror frequencies. DCF77 is no problem, MSC Crumbia is slightly visible, too. ELF stations like Russian Alpha RSDN20 are not visible. Setting sample-rate, filtering preamp etc. is quite tricky. Sometimes i had to restart SDRsharp.
I´m located right in the middle of Germany, my antenna is a Diamond Diskone D3000 (not really a VLF antenna, but it works perfectly with my Datong VLF converter), i successfully copied SAQ last time.
I attached two screenshots of the VLF spectrum, received with the same antenna at the same daytime and optimized settings for each setup. VLF can be received directly, but is difficult to get usable results.
73´s Joerg DL2ZBK
73´s Joerg DL2ZBK
- SDRplay VLF with DATONG
- SDRplay with DATONG.jpg (195.4 KiB) Viewed 30874 times
- SDRplay VLF direct
- SDRplay direct.jpg (194.65 KiB) Viewed 30874 times
I had no problem reciving SAQ Grimeton on 17.2 Khz today with SDRplay, was very clear on the waterfall, unfortunately no screenshot of hdsdr but I had my spectrumlabs running and here is a screenie, http://imgur.com/kJuiKRK
Outstanding results! Unfortunately I wasn't around for SAQ (again!).
What antennas are you guys using for VLF?
I was using my butternut hf9, not realy good at vlf but I liver quite close, just about 130Km from Grimeton.
Unbelievable, but i get best results with my Diamond D3000 Diskone antenna with approx. 15m H155 Antenna cable. I built up a magnetic loop trimmed exactly to 17.2 kHz, but the Diskone has a better SN ratio although the signal level is lower than the signal level of the loop. I´ll try to get my loop weather-resistant until christmas and will try again on christmas eve.
Joerg.
Joerg.
- 2015-06-28 142947 Bike-Loop SAQ.jpg (198.6 KiB) Viewed 30675 times
Hi Joerg.
I find nothing beats my Wellbrook 1530 loop for S/N at low frequencies. All my wires and verticals return lots of local domestic noise here. Only the loop cuts through it. I find the Wellbrook works well down to about 40 KHz at least. It's mounted on a cheap rotator at gutter height. I'm never home to listen for Grimeton.
