Default SSH username for the SDR Play Pi image
NeilP
Post by NeilP » Thu Jul 19, 2018 2:04 pm
Hi
Just installed a fresh image of the SDR Play Rasp Pi Distrubtion
But cannot SSH to it
Just get a
Connection closed by 192.168.1.49 port 22
If I swap SD cards for a fresh standard Raspbian Stretch Image I can SSH straight in with user ‘Pi’ and pwd ‘raspberry’
But the SDR Play image I cannot SSH to it
Have plugged in a monitor/keyboard/mouse and confirmed SSH is enabled, but still no joy, does not even get to the password prompt
Re: Default SSH username for the SDR Play Pi image
Post by sdrplay » Thu Jul 19, 2018 2:38 pm
You will need to:
sudo raspi-config
and use the menu system to enable remote access via SSH - it's disabled by default as a security feature.
NeilP
Post by NeilP » Thu Jul 19, 2018 3:15 pm
Thanks for the reply, but no...as per my question:
NeilP wrote: Have plugged in a monitor/keyboard/mouse and confirmed SSH is enabled, but still no joy, does not even get to the password prompt
I used the 'Create blank file named ssh' and drag to root of SD card method of enabling SSH.
Then used the GUI to confirm SSH was enabled..but still no.
Using the exact same procedure to create a Raspberian Stretch SD , SSH works, but not with the SDR Play image....
NeilP
Post by NeilP » Fri Jul 20, 2018 1:16 am
I've tried three times now
Re downloaded the SDR PLAY Rasp image and written fresh to new format SD card
Boot and use either the GUI config or cmd line and raspi config to enable SSH
REBOOT
go to other machine
Still get the "Connection closed by... " error
I can reboot the Pi (3B+) with a new image of Rasperian and enable SSH and get in with no issue.
Something seems 'broken ' in the SDRPlay image that prevents SSH ?
Post by sdrplay » Fri Jul 20, 2018 11:59 pm
Try this on the RPi...
sudo dpkg-reconfigure openssh-server
NeilP
Post by NeilP » Sat Jul 21, 2018 6:56 am
Yes, that did it
Am guessing that maybe it is to do with each instance of a different Pi OS, although on the same machine Creating a new key?
is it possible to set the same ECDSA key on multiple SD card OS's. so I can switch SD cards = reboot = and still have access via SSH without changing the know hosts file on the machine I am connecting from?
Post by sdrplay » Sat Jul 21, 2018 8:40 am
The original card we did had the ssh key and didn't have this problem, but it was pointed out that it was a security issue. So we took the keys off and now it appears that the keys have to be regenerated on an instance by instance basis to get ssh to work.
I'm not sure if the keys can be copied from device to device or whether they need to be regenerated each time. It would be something you could try.
NeilP
Post by NeilP » Sat Jul 21, 2018 11:42 am
What I thought I could try is give each SD card OS a different IP address, so same hardware has different IP. The known hosts file in the connecting computer having entry for each
If not, how do I go about putting it back ‘as it was’ so it has permanent key. Let the user choose if the risk is one they are prepared to have. I’ll do a few connects/disconnects and see what occurs
Post by sdrplay » Sat Jul 21, 2018 12:12 pm
Once you have one setup, then you could clone the SD card to other machines - that's how the first version of the card was setup.
NeilP
Post by NeilP » Sat Jul 21, 2018 5:09 pm
Yes, probably easier, been looking up setting static IP addresses and I see no GUI options.
For now I have created a desktop shortcut to the .ssh folder on my Windows machine. Every time I get the error I can just click the shortcut, go to the folder and delete the known hosts file. Then when ssh’ing in I get the msg about adding the key
