SDRPlay loses audio output when 7300 turned on
WA9ZVF
Post by WA9ZVF » Sat Jul 28, 2018 9:17 pm
I'm using an RSP2/Sdruno with Omnirig and an Icom 7300. Frequency and bands track between devices. If the RSP/Sdruno is running, I can listen to the audio on my computer speaker. Generally, when I turn on the power supply for the Icom 7300 I hear the "computer sound" that you get when a device is plugged into a USB over the sound from sdrplay (this seems strange). Generally, but not always, the SDR continues to have audio output. If I then switch ham bands using the keypad in sdrplay, the audio stops. It is not muted but rather just gone.
Although this may not have anything to do with the issue, when starting up sdrplay, get the following message: VRX#0 specified communications device doesn't exist or is already open.
Any way, any idea or hints on how to trouble shoot the problem?
Ray Mikula
WA9ZVF
