CubicSDR compile problems (Linux Mint 17)
MartinJ
Postby MartinJ » Fri Oct 30, 2015 11:21 am
Hi folks,
I'm trying to build the SDRplay software using the information provided for Ubuntu. This worked until I tried to compile CubicSDR. When typing "make" this error(s) came up. Packages "libwxgtk2.8-dev" and "libwxgtk2.8-dbg" are installed.
Any ideas what is missing? Thank you.
Martin
martin@martin-ThinkPad:~/sdrplay/CubicSDR/build# make
[  1%] Building CXX object CMakeFiles/CubicSDR.dir/src/CubicSDR.cpp.o
In file included from /home/martin/sdrplay/CubicSDR/src/AppFrame.h:6:0,
                 from /home/martin/sdrplay/CubicSDR/src/CubicSDR.h:18,
                 from /home/martin/sdrplay/CubicSDR/src/CubicSDR.cpp:15:
/home/martin/sdrplay/CubicSDR/src/visual/ScopeCanvas.h:62:23: error: ISO C++ forbids declaration of ‘wxDECLARE_EVENT_TABLE’ with no type [-fpermissive]
 wxDECLARE_EVENT_TABLE();
In file included from /home/martin/sdrplay/CubicSDR/src/AppFrame.h:7:0,
/home/martin/sdrplay/CubicSDR/src/visual/SpectrumCanvas.h:46:23: error: ISO C++ forbids declaration of ‘wxDECLARE_EVENT_TABLE’ with no type [-fpermissive]
[... lots of errors following]
Re: CubicSDR compile problems (Linux Mint 17)
Postby sdrplay » Fri Oct 30, 2015 1:31 pm
I've forwarded the issue to the developer. Hopefully he'll be able to throw some light on the issue.
Postby sdrplay » Sun Nov 01, 2015 9:29 pm
CubicSDR requires wx3.x (developer uses 3.0.2+), you only have wx2.8 - if you update that you should be ok.
pa1ap
Postby pa1ap » Sat Nov 07, 2015 11:22 pm
Could anyone confirm that sdrlay actually runs on linux mint 17? I have tried whole day various installs but it simply does not work for me.. I have followed the guidance provided. Is it confirmed running on mint 17?
mbott
Postby mbott » Wed Dec 30, 2015 4:50 pm
CubicSDR will most definitely run with the SDTplay under Linux 17.3 and Ubuntu 14.04LTS. I've built under both using the following:
https://github.com/cjcliffe/CubicSDR/wiki/Build-Linux
Mike
2 Knight Star Roamers Sony ICF-2010 Sangean ATS-909X Icom IC-R75 & IC-7300 Tecsun PL-660 Kenwood R-1000 & R-5000 Yeasu FRG-7 SDRplay RSP2 Airspy HF+ JRCNRD-535D CountyComm GP-5/SSB Pisel RF Pro-1B Wellbrook ALA1530LNP
