No RSP's Found Message After SDRuno Installation ?
Robert11
Post by Robert11 » Tue Oct 02, 2018 6:00 pm
Installed SDRuno on the windows side of my mac using
Parallels.
As far as I can tell, the installation went O.K.
But when I try to run it, I get the error msg.:
No Available RSP's Found
So, what's an RSP ?
What do I do now ?
Bob
Re: No RSP's Found Message After SDRuno Installation ?
Post by sdrplay » Tue Oct 02, 2018 7:10 pm
The RSP is what we produce (a Radio Spectrum Processor) - you have a RSP2 I believe.
When using Parallels, you have to make sure it has exclusive access to the RSP (it cannot be shared between Parallels and the Mac) - the easiest way to do that is to disconnect the RSP, then reconnect it - you should then get a window asking whether you want the RSP to be used on the Mac or on Parallels - select Parallels and then start SDRuno.
