Best baud rate for WX Sats
ZL2BMH
Postby ZL2BMH » Sun Oct 07, 2018 1:33 am
Hello All.
With RSP1a, SDRuno and WXtoimg. What is the best baud rate for weather NOAA Sats.
RSP2user
Re: Best baud rate for WX Sats
Postby RSP2user » Mon Oct 08, 2018 3:16 am
For what purpose are you looking for the baud rate? For example, if you are using a professional version of WXtoIMG and you wish to communicate using the Kenwood command set between the SDRuno and WXtoIMG so that WXtoIMG will control the frequency of the RSP1a, then apply the fastest baud rate available to WXtoIMG which is 57600, since the connection is a virtual local connection within the PC between WXtoIMG and RSPuno. This type of setup will allow WXtoIMG to change the frequency of the RSP to accommodate the various NOAA satellites as they come into range and additionally the frequency will be changed automatically by WXtoIMG to account for Doppler shift. To connect the serial port between WXtoIMG and SDRuno, you will need a virtual serial port emulator, such as VSPE. Here is an article that discusses a NOAA reception setup using VSPE for connecting SDRuno to WXtoIMG: viewtopic.php?f=5&t=2529
