SDRPlay installation on Odroid XU4
WA2ZKD
Postby WA2ZKD » Sat Oct 27, 2018 1:48 pm
SoapySDR installs OK but when I try to do the SDRplay part I get:
[ 20%] Linking CXX shared module libsdrPlaySupport.so
/usr/local/lib/libmirsdrapi-rsp.so: file not recognized: File format not recognized
collect2: error: ld returned 1 exit status
CMakeFiles/sdrPlaySupport.dir/build.make:174: recipe for target 'libsdrPlaySupport.so' failed
make[2]: *** [libsdrPlaySupport.so] Error 1
CMakeFiles/Makefile2:67: recipe for target 'CMakeFiles/sdrPlaySupport.dir/all' failed
make[1]: *** [CMakeFiles/sdrPlaySupport.dir/all] Error 2
Makefile:129: recipe for target 'all' failed
make: *** [all] Error 2
Re: SDRPlay installation on Odroid XU4
Postby sdrplay » Sat Oct 27, 2018 3:17 pm
Looks like you have the wrong API installed.
ARM64 for 64bit ARM processor based systems and the RPI API for 32bit ARM processor based systems.
The XU4 is a 32bit ARM processor system so you want the Rasperry Pi API
