How to share SDRplay and a Transceiver with an external receiver ?
dustin
Postby dustin » Thu Nov 19, 2015 5:12 pm
I found this Tutorial to use the SRDplay and a Transceiver on the same external Antenna.
http://arcticpeak.blogspot.no/2015/10/how-to-share-common-antenna-with.html
https://www.youtube.com/watch?v=fDq_0BCgpdE
Does it work or will it damage the receiver?
Is there another way?
Thanks and best regards, Dustin
NN4F
Re: How to share SDRplay and a Transceiver with an external receiver ?
Postby NN4F » Thu Nov 19, 2015 9:54 pm
There are other ways also, it depends on the transceiver a lot, I use the Yaesu FTdx3000 and have the option of IF out or RX out, and no switches are needed... What radio are you trying to use it with??
Paul - NN4F
dustin
Postby dustin » Sat Nov 21, 2015 6:41 pm
The possibilities of SDR radios inspire me but I have no HAM radio license so far , so I want to use my old CB radios for Transmission.
The options here are very limited.There are no special RF or IF outputs available.
the only way I've found is the elad switchbox, but I dont know if the Isolation by transmission is high enough that the SDR does not damage.
Thank you for your quick response.
73 Dustin
Users browsing this forum: w7qex and 10 guests
