RSP1A will not connect on boot up
Posted: Fri Jan 11, 2019 6:29 pm
by cmsnow
My RSP1A will not connect on PC boot up. However, after boot up, if I unplug it and plug it back in it will connect and everything works fine. On boot up, it seems to be an unidentified USB device. After unplug/plug it appears under Sound, video and game controllers
Suggestions?
Re: RSP1A will not connect on boot up
Posted: Fri Jan 11, 2019 8:25 pm
by Mike2459
I have had this happen when standby power was turned off. Standby power is off when the power supply switch is turned off or if line power is removed.
Posted: Fri Jan 11, 2019 9:20 pm
by cmsnow
Mike2459 wrote:I have had this happen when standby power was turned off. Standby power is off when the power supply switch is turned off or if line power is removed.
OK, mine is similar. I turn on the PC from an external power switch. So all power is off before initial boot up.
Now what? SDRPlay engineers, why would it do this and how to fix it?
