SDRPlay RSP2 & GQRX Ubuntu 18 works ... but ...
hb9rxc
Postby hb9rxc » Sat Jan 19, 2019 6:06 pm
Hello List,
finally I managed how to install all under Ubuntu 18.04 to use GNUradio-Companion and GQRX via gr-osmosdr !! :D
Well after all is quite simple if you follow some "clear instructions" and "how-to" ......... next week I will try it also under Ubuntu 16.04 ... need some manual adjustement .........
Just need to solve a problem with RSP-2 (multiple antenna input) and GQRX. How to switch between input using gr-osmosdr driver ?????
Regards, Pietro
fventuri
Re: SDRPlay RSP2 & GQRX Ubuntu 18 works ... but ...
Postby fventuri » Sun Jan 20, 2019 9:46 pm
Pietro,
it should be under the 'Input controls' frame (see here: http://gqrx.dk/doc/practical-tricks-and-tips).
If you don't see that panel, you might need to enable it by selecting 'Input controls' in the 'View' menu.
Franco
