problem dump1090
whiteghost
problem dump1090
Postby whiteghost » Sat Feb 02, 2019 6:08 pm
sorry my english, i am italian, i own a rsp2, i would like to use dump1090, i downloaded the software, but it does not receive any airplane, where is the problem?
Re: problem dump1090
Postby Tech_Support » Sat Feb 02, 2019 6:29 pm
Hello whiteghost,
Are you using port B? This is the default port for dump1090.
whiteghost
Postby whiteghost » Sat Feb 02, 2019 6:56 pm
the antenna is connected to port b, it is a comet gp-9
Postby Tech_Support » Sat Feb 02, 2019 9:31 pm
I suggest that you open a support ticket via www.sdrplay.com/support
Please provide details of the software that you have installed, what OS you are using, how you run the software and exactly what you see. Ideally, please provide screen shots.
navzptc
Postby navzptc » Sun Feb 03, 2019 1:16 am
whiteghost wrote:the antenna is connected to port b, it is a comet gp-9
Perhaps that's your problem, the comet gp-9 is a Dualband (2m / 70Cms) base station antenna and not one specifically for ADS-B signals at 1090 Mhz!
whiteghost
Postby whiteghost » Sun Feb 03, 2019 9:59 am
if I use a diamond d130 discone?
Postby Tech_Support » Sun Feb 03, 2019 10:06 am
The discone should work fine if it is mounted correctly (outside and as high as possible). You will get much better performance if you build a simple multi-element co-linear antenna.
