Linux remote server with Windows client
Hello everyone. I've successfully got my SDRPlay working in Linux using CubicSDR. I've also compiled SoapyRemote and it can connect to my SDRPlay. I can also use CubicSDR to connect to the SoapyRemoteServer on the local machine. I've tried the CubicSDR windows install but it won't even run properly. It opens a command windows and has "RTL Devices: 0" and it also has a window that the title says "RTL-SDR device not found" with few garbage characters and an ok button. Click ok and it just closes. I haven't seen much in the way of documentation for Cubic on windows so I'm not sure where to start.
Thanks for the help.
Re: Linux remote server with Windows client
The newest 0.1.18 Alpha compiled binary runs fine on Win10 try from here and grab the version you need either 32 or 64
https://github.com/cjcliffe/CubicSDR/re ... 1.18-alpha
