SDRplay and Airprobe
fe8769
Postby fe8769 » Sun Jan 03, 2016 10:20 pm
Now TETRA decode is working with Sdrplay .I try to run Airprobe GSM project
I have the following error :
sudo ./airprobe_rtlsdr.py -f 9.584e+08 -g 49.6
[sudo] password for gnuradio37:
linux; GNU C++ version 4.8.4; Boost_105400; UHD_003.010.git-89-gb17b440d
gr-osmosdr v0.1.4-57-g55fe9619 (0.1.5git) gnuradio 3.7.8.1
built-in source types: file osmosdr fcd rtl rtl_tcp uhd miri sdrplay hackrf bladerf rfspace airspy soapy redpitaya
get_devices started
mir_sdr_Init: gR=60dB fs=2,048MHz rf=200,000MHz bw=1,536MHz if=0,000MHz
Warning: libusb_claim_interface() -6
mir_sdr_2500_Init: fnaddr = 15
initHw: Register7 = 0x000005
initHw: Tuner Register0 = 0x04f440
mir_sdr_SetFs: Sample Freq requested 2047999,978065
mir_sdr_SetFs: Fs->FsNomHz+dFsHz=2048000,0+0,0Hz=2048000,0Hz FsToggle->1
mir_sdr_SetRf: f->200000000,000Hz (int=21 frac=3e8 afc=0) fSynth:3200000000,000
mir_sdr_SetRf: Rf->RfNomHz+dRfHz+LifHz+Lif1Hz=200000000,0+0,0+0,0Hz+0,0Hz=200000000,0Hz RfToggle->1
mir_sdr_SetGr: GR->60[36,24,0,0] gRset->0x224 DCCALmode=4 DCCALspd=1 GrToggle->1
setToggleStates: initialising sampNum=0x0001f802, gainSetting=0x224, FsToggle=0, RfToggle=1, GrToggle=1
setToggleStates: initialising Fs=2047999,978, Rf=200000000,000, Gr=60
mir_sdr_Init: already initialised
Device count: 1
mir_sdr_2500_Readback001Trim: readback = 0xe442e0f
mir_sdr_2500_Bypass001Trim: reg13=0x1ed reg14=0x7102ee
sdrplay=0,label='SDRplay RSP'
get_devices end
mir_sdr_Init: gR=40dB fs=2,048MHz rf=222,064MHz bw=1,536MHz if=0,000MHz
mir_sdr_SetRf: f->222064000,000Hz (int=25 frac=20 afc=0) fSynth:3553024000,000
mir_sdr_SetRf: Rf->RfNomHz+dRfHz+LifHz+Lif1Hz=222064000,0+0,0+0,0Hz+0,0Hz=222064000,0Hz RfToggle->1
mir_sdr_SetGr: GR->40[16,24,0,0] gRset->0x210 DCCALmode=4 DCCALspd=1 GrToggle->1
setToggleStates: initialising sampNum=0x0001f802, gainSetting=0x210, FsToggle=0, RfToggle=0, GrToggle=0
setToggleStates: initialising Fs=2047999,978, Rf=222064000,000, Gr=40
mir_sdr_2500_Readback001Trim: readback = 0xe34180f
mir_sdr_2500_Bypass001Trim: reg13=0x1ed reg14=0x6d018e
Using device #0: Mirics MSi2500 default (e.g. VTX3D card)
usb_claim_interface error -6
FATAL: Failed to open mirisdr device.
Trying to fill up 1 missing channel(s) with null source(s).
This is being done to prevent the application from crashing
due to gnuradio bug #528.
Using Volk machine: sse4_2_64_orc
Traceback (most recent call last):
File "./airprobe_rtlsdr.py", line 267, in <module>
tb = airprobe_rtlsdr(fc=options.fc, gain=options.gain, ppm=options.ppm, samp_rate=options.samp_rate, shiftoff=options.shiftoff)
File "./airprobe_rtlsdr.py", line 158, in __init__
self.blocks_socket_pdu_0_0 = blocks.socket_pdu("UDP_SERVER", "127.0.0.1", "4729", 10000, False)
File "/usr/local/lib/python2.7/dist-packages/gnuradio/blocks/blocks_swig5.py", line 950, in make
return _blocks_swig5.socket_pdu_make(*args, **kwargs)
RuntimeError: bind: Adresse déjà utilisée
gnuradio37@gnuradio37-virtual-machine:~/Documents/gr-gsm/apps$
SDRplay is running with cubicsdr , GQRX and TETRA decoder on the same PC
fe8769
Re: SDRplay and Airprobe
Postby fe8769 » Thu Feb 11, 2016 9:24 pm
Up to this message
I tried to remake gr-gsm but still same error
I m using xubuntu 14.4
Sdrplay is working fine with cubicsdr
I reinstalled gr-osmosdr
still error :
please help
fe8769
Postby fe8769 » Fri Feb 19, 2016 1:33 pm
Team support please answer to the :
On this configuration
Cubic sdr 1.20 with photosware is working fine
GQRX V2.3.2-193-gbbed is working fine
TETRA is working
osmocom_fft is working
gr-gsm NO : error usb claim -6
Postby Tech_Support » Fri Feb 19, 2016 2:21 pm
Dear fe8769,
I am a bit confused about your reference to the VTX3D card. We don't understand the relevance that this may have to the SDRplay RSP. If you are using the mirisdr driver, we should point out that this is an unofficial driver that was not developed by us or as far as we are aware by Mirics and we are unable to provide any support for it.
Users browsing this forum: OH2BUA and 12 guests
