SDRplay and Airprobe
Posted: Sun Jan 03, 2016 10:20 pm
Now TETRA decode is working with Sdrplay .I try to run Airprobe GSM project
I have the following error :
sudo ./airprobe_rtlsdr.py -f 9.584e+08 -g 49.6
[sudo] password for gnuradio37:
linux; GNU C++ version 4.8.4; Boost_105400; UHD_003.010.git-89-gb17b440d
gr-osmosdr v0.1.4-57-g55fe9619 (0.1.5git) gnuradio 3.7.8.1
built-in source types: file osmosdr fcd rtl rtl_tcp uhd miri sdrplay hackrf bladerf rfspace airspy soapy redpitaya
get_devices started
mir_sdr_Init: gR=60dB fs=2,048MHz rf=200,000MHz bw=1,536MHz if=0,000MHz
Warning: libusb_claim_interface() -6
mir_sdr_2500_Init: fnaddr = 15
initHw: Register7 = 0x000005
initHw: Tuner Register0 = 0x04f440
mir_sdr_SetFs: Sample Freq requested 2047999,978065
mir_sdr_SetFs: Fs->FsNomHz+dFsHz=2048000,0+0,0Hz=2048000,0Hz FsToggle->1
mir_sdr_SetRf: f->200000000,000Hz (int=21 frac=3e8 afc=0) fSynth:3200000000,000
mir_sdr_SetRf: Rf->RfNomHz+dRfHz+LifHz+Lif1Hz=200000000,0+0,0+0,0Hz+0,0Hz=200000000,0Hz RfToggle->1
mir_sdr_SetGr: GR->60[36,24,0,0] gRset->0x224 DCCALmode=4 DCCALspd=1 GrToggle->1
setToggleStates: initialising sampNum=0x0001f802, gainSetting=0x224, FsToggle=0, RfToggle=1, GrToggle=1
setToggleStates: initialising Fs=2047999,978, Rf=200000000,000, Gr=60
mir_sdr_Init: already initialised
Device count: 1
mir_sdr_2500_Readback001Trim: readback = 0xe442e0f
mir_sdr_2500_Bypass001Trim: reg13=0x1ed reg14=0x7102ee
sdrplay=0,label='SDRplay RSP'
get_devices end
mir_sdr_Init: gR=40dB fs=2,048MHz rf=222,064MHz bw=1,536MHz if=0,000MHz
mir_sdr_SetRf: f->222064000,000Hz (int=25 frac=20 afc=0) fSynth:3553024000,000
mir_sdr_SetRf: Rf->RfNomHz+dRfHz+LifHz+Lif1Hz=222064000,0+0,0+0,0Hz+0,0Hz=222064000,0Hz RfToggle->1
mir_sdr_SetGr: GR->40[16,24,0,0] gRset->0x210 DCCALmode=4 DCCALspd=1 GrToggle->1
setToggleStates: initialising sampNum=0x0001f802, gainSetting=0x210, FsToggle=0, RfToggle=0, GrToggle=0
setToggleStates: initialising Fs=2047999,978, Rf=222064000,000, Gr=40
mir_sdr_2500_Readback001Trim: readback = 0xe34180f
mir_sdr_2500_Bypass001Trim: reg13=0x1ed reg14=0x6d018e
Using device #0: Mirics MSi2500 default (e.g. VTX3D card)
usb_claim_interface error -6
FATAL: Failed to open mirisdr device.
Trying to fill up 1 missing channel(s) with null source(s).
This is being done to prevent the application from crashing
due to gnuradio bug #528.
Using Volk machine: sse4_2_64_orc
Traceback (most recent call last):
File "./airprobe_rtlsdr.py", line 267, in <module>
tb = airprobe_rtlsdr(fc=options.fc, gain=options.gain, ppm=options.ppm, samp_rate=options.samp_rate, shiftoff=options.shiftoff)
File "./airprobe_rtlsdr.py", line 158, in __init__
self.blocks_socket_pdu_0_0 = blocks.socket_pdu("UDP_SERVER", "127.0.0.1", "4729", 10000, False)
File "/usr/local/lib/python2.7/dist-packages/gnuradio/blocks/blocks_swig5.py", line 950, in make
return _blocks_swig5.socket_pdu_make(*args, **kwargs)
RuntimeError: bind: Adresse déjà utilisée
gnuradio37@gnuradio37-virtual-machine:~/Documents/gr-gsm/apps$
SDRplay is running with cubicsdr , GQRX and TETRA decoder on the same PC
get_devices started
Device count: 1
get_devices end
