Choppy audio with Linux and CubicSDR?
I have a RSPduo and have installed Ubuntu Linux in a VM on my Mac. Followed the work flow instructions to get CubicSDR running and it does see the RSPduo device and can see signals and tune them in OK. The audio however is choppy, sounding like is is being gated on/off every few hundred milliseconds.
The only audio option I see in the dropdown box is Pulse Audio.
As additional info, I have the RSPduo working fine with CubicSDR on native OS X. It's also working ok using SDRPlay and SDRConsole on Windows 10.
Re: Choppy audio with Linux and CubicSDR?
Why run Cubic in a VM on your mac when Cubic has a native DMG installer?
I've observed similar choppy audio on my LAN with SoapySDRplay as the server even with the new Raspberry Pi Image, typically I lower the "Sample Rate" in the GUI of CubicSDR before starting the device. I've read various 3rd party posts about adjusting frame buffers and such but nothing I've tried so far produces consistent results. This seems like it was not an issue with previous versions (17.04 variants) of ubuntu. Only conjecture on my part, but even streaming on my local LAN has been pretty fussy, and sometimes the CubicSDR UI will straight up freeze and then crash on the local desktop.
Note this is a regular install of Ubuntu, not virtualized so I suspect there's some network connection optimization for the streaming bandwidth I need to look into.
I also own a CloudIQ, and it's similarly fussy with GQRX and even it's native app under Wine. Still investigating here.
