ATV decoding with SDRplay
DL8CQ
Postby DL8CQ » Sat Jan 23, 2016 1:40 pm
recently an ATV relay went on Air in my area. It sends signals at 1280 MHz. Normally one would take an analog satellite receiver to decode the signal, but I am wondering if it is possible to do this with my little sdrplay? With 8 MHz bandwidth it should be possible to decode even the color information.
I tried to get TVSharp running, but it seems that the latest SDR# downloaded a few days ago and the latest version of TVSharp (also downloaded a few days ago from the russian plugin website) are not compatible.
I got an error about a different compiler version of the plugin - sorry, did not make a screenshot and now SDR# is just running without error message but no TV plugin appears :-(
Has anybody an idea about how to decode analog amateur TV or could point me to a working package SDR# + TVSharp so I could at least get B+W TV signal?
BR, 73
Martin
andyj
Re: ATV decoding with SDRplay
Postby andyj » Sun Jan 24, 2016 8:14 am
Hi Martin.
There's an older version of SDR# ( 1361 ) here that might just be compatable. Can't guarantee anything but it may be worth trying.
http://www.radioscanner.ru/files/receiv ... /file18851
mark1992
Postby mark1992 » Fri Aug 05, 2016 6:29 am
DL8CQ wrote:Hi,
recently an vegas atv tours relay went on Air in my area. It sends signals at 1280 MHz. Normally one would take an analog satellite receiver to decode the signal, but I am wondering if it is possible to do this with my little sdrplay? With 8 MHz bandwidth it should be possible to decode even the color information.
BR, 73
Martin
I have the same problem from 3 weeks. I also not getting proper solution about that. If you get solution. Please update me.
KM4JOJ
Postby KM4JOJ » Wed Aug 31, 2016 5:21 pm
The plugin for SDR# I seem to recall will not decode NTSC. Which doesnt matter because the program doesnt seem to do anything with color or sound.
It was designed for 2mhz 8bit dongles.
F1BJB
Postby F1BJB » Fri Sep 23, 2016 7:39 pm
Analog satellite uses FM modulation the plugins are designed for AM modulation and useless in that case.
