Strange signal?
lordkev
Strange signal?
Postby lordkev » Sun Jan 24, 2016 11:09 pm
I am seeing the following signal throughout the spectrum all the way from HF (10m, 6m) up into VHF (2m). It appears to be some kind of timecode signal. I thought it was a harmonic, but it's definitely quite strong even up in the 2m band. Any idea what the source might be?
GrahamC
Re: Strange signal?
Postby GrahamC » Thu Jan 28, 2016 2:47 pm
Hard to tell from what you have posted.
However, from your description and screenshot if I was to make a guess, it looks like the type of RFI / EMI you will see from wired ethernet/networking. You will find this type of EMI / RFI from HF through VHF at regular intervals and has a repetitive sound and pattern.
Putting clamp on ferrites on the cables near your routers, computer, and the SDRPlay may help, it all depends on how the RFI/EMI is finding it's way into your receiver - i.e. through your antenna or through your cabling as common mode. If you are using a simple whip antenna on your SDRPlay you might try using a longer piece of cable and separating the receiver and antenna by some distance which may help reduce the level of the interfering signal.
EMI - Electro Magnetic Interference
RFI - Radio Frequency Interference
cheers, Graham
