The station name thing
13dka
Re: The station name thing
Post by 13dka » Sun Feb 21, 2016 6:37 pm
I'm afraid I can't, HDSDR is not loading the plug-in after showing the error message.
rpaulrob
Post by rpaulrob » Sun Feb 21, 2016 6:40 pm
I cannot get it going either. When I check the advanced page EXT io station configure under Database Status nothing shows. I am connected to Internet. Have rebooted and still no luck. How does one get the database to load?
Fractal1
Post by Fractal1 » Sun Feb 21, 2016 10:31 pm
I have the very same issue with HDSDR crashing now, but on windows xp system. Installing an earlier EXTIO works.
jon
Post by jon » Sun Feb 21, 2016 11:10 pm
Video demo of station naming on http://youtu.be/5c9chmRtBjw
John_G4ACP
Post by John_G4ACP » Sun Feb 21, 2016 11:59 pm
I also just updated to API 1.8.1 from 1.6.0 and EXTIO to 3.8.1 from 3.6.
HDSDR 2.7 now fails to launch HDSDR with :-
Application popup: SDRplay RSP Device Controller: HDSDR.exe - Application Error : The instruction at "0x7c911766" referenced memory at "0x000986f2". The memory could not be "read".
This was super stable on Windows XP SP3 before.
SD Console launches fine, I restarted the PC, uninstalled everything and re-installed no joy.
I've now reinstalled API 1.6.0and EXTIO 3.6 and all is back to normal.
I'm an IT Professional, so I've covered all the correct steps :)
RSP#121115#11#157
Thanks ..
John
13dka
Post by 13dka » Mon Feb 22, 2016 2:41 am
Fractal1 wrote:I have the very same issue with HDSDR crashing now, but on windows xp system. Installing an earlier EXTIO works.
Are you getting a real crash (standard Windows crash window "Blah blah has stopped working") or the same/a similar exception error window from HDSDR like on my screenshot on the previous page? I take it you're using XP 32 bit?
Did you install the EiBi (or some other) shortwave frequency database in HDSDR at some point?
rpaulrob
Post by rpaulrob » Mon Feb 22, 2016 3:36 am
Thank you for the video. Saw what I was doing wrong. Much appreciated.
Fractal1
Post by Fractal1 » Mon Feb 22, 2016 5:58 am
13dka,
i get the same HDSDR error/crash window as you posted on the first page. To my knowledge i haven't done anything with the eibi database.
Fractal1
Post by Fractal1 » Mon Feb 22, 2016 6:13 am
Just to add further, yes i'm xp 32 bit. Here is my error:
hdsdr crash.png (13.1 KiB) Viewed 6556 times
Post by sdrplay » Mon Feb 22, 2016 11:37 am
This is a known issue on some machines which I'm working on.
For now, you can download this zip file: http://www.sdrplay.com/software/disable ... lookup.zip
make sure HDSDR is not running, extract the reg file out of the zip file, double click on the reg file
restart HDSDR - this disables the station lookup and returns 3.8.1 to 3.7 functionality.
We are looking into the issues causing the crash and will update you as soon as we can with a solution.
