The station name thing
Re: The station name thing
I'm afraid I can't, HDSDR is not loading the plug-in after showing the error message.
I cannot get it going either. When I check the advanced page EXT io station configure under Database Status nothing shows. I am connected to Internet. Have rebooted and still no luck. How does one get the database to load?
I have the very same issue with HDSDR crashing now, but on windows xp system. Installing an earlier EXTIO works.
Video demo of station naming on http://youtu.be/5c9chmRtBjw
I also just updated to API 1.8.1 from 1.6.0 and EXTIO to 3.8.1 from 3.6.
HDSDR 2.7 now fails to launch HDSDR with :-
Application popup: SDRplay RSP Device Controller: HDSDR.exe - Application Error : The instruction at "0x7c911766" referenced memory at "0x000986f2". The memory could not be "read".
This was super stable on Windows XP SP3 before.
SD Console launches fine, I restarted the PC, uninstalled everything and re-installed no joy.
I've now reinstalled API 1.6.0and EXTIO 3.6 and all is back to normal.
I'm an IT Professional, so I've covered all the correct steps
RSP#121115#11#157
Thanks ..
John
RSP#121115#11#157
Thanks ..
John
Are you getting a real crash (standard Windows crash window "Blah blah has stopped working") or the same/a similar exception error window from HDSDR like on my screenshot on the previous page? I take it you're using XP 32 bit?Fractal1 wrote:I have the very same issue with HDSDR crashing now, but on windows xp system. Installing an earlier EXTIO works.
Did you install the EiBi (or some other) shortwave frequency database in HDSDR at some point?
Thank you for the video. Saw what I was doing wrong. Much appreciated.
13dka,
i get the same HDSDR error/crash window as you posted on the first page. To my knowledge i haven't done anything with the eibi database.
Just to add further, yes i'm xp 32 bit. Here is my error:
- hdsdr crash.png (13.1 KiB) Viewed 25653 times
This is a known issue on some machines which I'm working on.
For now, you can download this zip file: http://www.sdrplay.com/software/disable ... lookup.zip
make sure HDSDR is not running, extract the reg file out of the zip file, double click on the reg file
restart HDSDR - this disables the station lookup and returns 3.8.1 to 3.7 functionality.
We are looking into the issues causing the crash and will update you as soon as we can with a solution.
