mir_sdr_2500_StreamInit() Error 0x00000001
dtaviation
Post by dtaviation » Thu Mar 03, 2016 3:59 pm
Would someone be able to suggest why intialising the connection to the radio might sometimes fail:
mir_sdr_2500_Init: fnaddr = 15
mir_sdr_2500_StreamInit: Open failed
initHw: mir_sdr_2500_StreamInit() Error 0x00000001
mir_sdr_Init: initState returns error 7
HW: 2014 Mac Mini, SW: Fedora 23, gr-osmosdr.
Dave
Re: mir_sdr_2500_StreamInit() Error 0x00000001
Post by sdrplay » Thu Mar 03, 2016 10:21 pm
Can you confirm that you are using the official driver with SoapySDR? Can you post the output of...
SoapySDRUtil --probe=sdrplay
Thanks and best regards,
dtaviation
Post by dtaviation » Thu Mar 03, 2016 10:52 pm
Thanks for that, this shows a problem. However, sometimes the radio starts ok.
$ SoapySDRUtil --probe=sdrplay
Probe device sdrplay
[ERROR] SoapySDR::loadModule(/usr/local/lib64/SoapySDR/modules/libremoteSupport.so)
dlopen() failed: /usr/local/lib64/SoapySDR/modules/libremoteSupport.so: undefined symbol: _ZN8SoapySDR8RegistryC1ERKSsRKPFSt6vectorISt3mapISsSsSt4lessISsESaISt4pairIS1_SsEEESaISA_EERKSA_ERKPFPNS_6DeviceESE_ES2_
[ERROR] SoapySDR::loadModule(/usr/local/lib64/SoapySDR/modules/librtlsdrSupport.so)
dlopen() failed: /usr/local/lib64/SoapySDR/modules/librtlsdrSupport.so: undefined symbol: _ZN8SoapySDR6Device18setFrontendMappingEiRKSs
-- Device identification
driver=null
hardware=null
-- Peripheral summary
Channels: 0 Rx, 0 Tx
Timestamps: NO
Here is the full output when I try to start:
g2 = 0x4801
initHw: Register7 = 0x000c94
initHw: Tuner Register0 = 0x05f500
Error: libusb_submit_transfer() -1
mir_sdr_2500_Readback001Trim: readback = 0xe240412
mir_sdr_2500_Bypass001Trim: reg13=0x24d reg14=0x69004e
DRT 1 mir_sdr_SetDcMode started
reinit_device end
in destructor: _running=1
mir_sdr_Uninit started
dtaviation
Post by dtaviation » Fri Mar 04, 2016 12:25 am
The SoapySDRUtil command was very helpful, thanks.
After having:
1) Removed the offending libraries, which were put there by a build of SoapyRemote
2) Reinstalling your API, and
2) Rebuilding gr-osmosdr and SoapySDR
I now have a working radio again.
Excellent support.
