Ordered rsp inted with Ubuntu Linux..concerned
WCat
Postby WCat » Wed Mar 16, 2016 6:09 pm
Hi folks
Running Ubuntu 14.04 and ordered the rsp today. The more I read the more concerned I am becoming. I've read that an open driver was being developed and even saw that it had been on Google groups, though when I follow the github link I receive a 404.
What is the status of running gqrx with the rsp? Seems the direction I would like to go.
If not what are my options for a nice gui preferably without wine or virtual machines? I try to avoid proprietary software whenever possible and as such no nvidea drivers.
As I am new to sdr just trying to get my ducks in a row and understand the sdr community in the process.
Hoping someone can steer me in the right direction for best results.
Best regards
WCat
Re: Ordered rsp inted with Ubuntu Linux..concerned
Postby sdrplay » Wed Mar 16, 2016 6:48 pm
The best supported option is CubicSDR (the API installation will also contain SoapySDR/SoapySDRPlay which you need to communicate with the RSP)
http://cubicsdr.com - it's still in development but already becoming pretty popular.
WCat
Postby WCat » Wed Mar 16, 2016 7:24 pm
OK thank you that is the path I will take. Sorry about the double post.
updatelee
Postby updatelee » Thu Mar 17, 2016 6:27 pm
Is there actually an open source driver in development? It's the only thing holding me back right now.
UDL
WCat
Postby WCat » Fri Mar 18, 2016 1:26 pm
I managed to get everything up and running on elementary os 64bit.
I used pip/pybombs to install gr-osmosdr.
SoapySDRUtil --probe=sdrplay
Probe device sdrplay
mir_sdr_Init: gR=40dB fs=2.048MHz rf=222.064MHz bw=1.536MHz if=0.000MHz
Warning: libusb_claim_interface() -6
mir_sdr_2500_Init: revisionId = 0x0200, doing FW update
mir_sdr_2500_Init: fnaddr = 2 detected, trying to change...
mir_sdr_2500_Init: fnaddr = 10
initHw: Register7 = 0x000005
mir_sdr_SetRf: f->222064000.000Hz (int=25 frac=20 afc=0) fSynth:3553024000.000
mir_sdr_SetRf: Rf->RfNomHz+dRfHz+LifHz+Lif1Hz=222064000.0+0.0+0.0Hz+0.0Hz=222064000.0Hz RfToggle->1
setToggleStates: initialising sampNum=0x0001fe5e, gainSetting=0x210, FsToggle=0, RfToggle=1, GrToggle=1
setToggleStates: initialising Fs=2047999.978, Rf=222064000.000, Gr=40
mir_sdr_2500_Readback001Trim: readback = 0xe30160e
mir_sdr_2500_Bypass001Trim: reg13=0x1cd reg14=0x6c016e
-- Device identification
  driver=SDRPlay
  hardware=SDRPlay
  mir_sdr_version=1.700000
-- Peripheral summary
  Channels: 1 Rx, 0 Tx
  Timestamps: NO
  Other Settings:
     * Low IF (when available) - Use low IF when available: 0.5MHz SR with 200 and 300khz BW, 1MHz SR with 600kHz BW, 2048kHz SR with 1536kHz BW
       [key=use_low_if, default=true, type=bool]
-- RX Channel 0
  Full-duplex: YES
  Supports AGC: NO
  Stream formats: CS16, CF32
  Native format: CS16 [full-scale=2048]
  Antennas: RX
  Corrections: DC removal, DC offset
  Full gain range: [0, 204] dB
    TUNER gain range: [0, 102] dB
    LNAT gain range: [0, 102] dB
  Full freq range: [0.1, 2000] MHz
    RF freq range: [0.1, 2000] MHz
  Sample rates: [0.222222, 12] MHz
I am awaiting an antenna and currently have a wifi antenna screwed into it. I am way over my head technically. Cubicsdr is working with the rsp though I am not able to pick up anything, just static with the occasional signal that just quiets the satic. Praying to the gods of ignorance that it is my antenna though I doubt it. Anyone willing to help me along this weekend when I will have some time?
Is this warning a problem?
Any help or insight appreciated
Thank you all
WCat
Postby sdrplay » Fri Mar 18, 2016 2:36 pm
yes, that libusb error will be a problem - that is saying that something else has grabbed the device. Using lsmod, check to see if there is anything like msi001, msi2500 or sdr_msi3101 loaded - these will cause a problem and will need to be blacklisted.
If not, then you need to make sure only 1 application is accessing the RSP at any one time.
WCat
Postby WCat » Fri Mar 18, 2016 2:58 pm
Excellent response time. I have a little one that I have to keep occupied today so my participation will be sporadic.
looks like msi001.
$ lsmod
Module                  Size  Used by
msi001                 14448  1
sdr_msi3101            34402  0
videobuf2_vmalloc      13216  1 sdr_msi3101
videobuf2_memops       13362  1 videobuf2_vmalloc
videobuf2_core         59104  1 sdr_msi3101
v4l2_common            15681  3 sdr_msi3101,msi001,videobuf2_core
videodev              153793  4 sdr_msi3101,msi001,v4l2_common,videobuf2_core
media                  21903  1 videodev
nvram                  14411  0
msr                    12865  0
cuse                   13445  3
uas                    27255  0
usb_storage            66545  1 uas
snd_hda_codec_hdmi     47548  4
rfcomm                 69509  0
bnep                   19624  2
bluetooth             446409  10 bnep,rfcomm
6lowpan_iphc           18702  1 bluetooth
dm_crypt               23216  1
arc4                   12608  2
wl                   6367833  0
iwldvm                232283  0
mac80211              652777  1 iwldvm
intel_powerclamp       18823  0
snd_hda_codec_idt      59808  1
snd_hda_codec_generic    69011  1 snd_hda_codec_idt
coretemp               13441  0
snd_hda_intel          30549  5
snd_hda_controller     30228  1 snd_hda_intel
kvm_intel             143630  0
snd_hda_codec         139719  5 snd_hda_codec_hdmi,snd_hda_codec_idt,snd_hda_codec_generic,snd_hda_intel,snd_hda_controller
kvm                   456292  1 kvm_intel
snd_hwdep              17698  1 snd_hda_codec
snd_pcm               104112  4 snd_hda_codec_hdmi,snd_hda_codec,snd_hda_intel,snd_hda_controller
dell_rbtn              13621  0
snd_seq_midi           13564  0
crct10dif_pclmul       14307  0
snd_seq_midi_event     14899  1 snd_seq_midi
dell_laptop            18354  0
crc32_pclmul           13133  0
snd_rawmidi            30876  1 snd_seq_midi
dcdbas                 14928  1 dell_laptop
dell_wmi               12761  0
pcmcia                 62299  0
sparse_keymap          13948  1 dell_wmi
snd_seq                63074  2 snd_seq_midi_event,snd_seq_midi
aesni_intel           152552  2090
aes_x86_64             17131  1 aesni_intel
lrw                    13286  1 aesni_intel
snd_seq_device         14497  3 snd_seq,snd_rawmidi,snd_seq_midi
gf128mul               14951  1 lrw
glue_helper            13990  1 aesni_intel
ablk_helper            13597  1 aesni_intel
iwlwifi               179412  1 iwldvm
cryptd                 20359  1046 aesni_intel,ablk_helper
snd_timer              29575  2 snd_pcm,snd_seq
joydev                 17393  0
serio_raw              13483  0
yenta_socket           41040  0
pcmcia_rsrc            18407  1 yenta_socket
intel_ips              18484  0
cfg80211              498458  4 wl,iwlwifi,mac80211,iwldvm
lpc_ich                21093  0
pcmcia_core            23592  3 pcmcia,pcmcia_rsrc,yenta_socket
snd                    79468  21 snd_hwdep,snd_timer,snd_hda_codec_hdmi,snd_hda_codec_idt,snd_pcm,snd_seq,snd_rawmidi,snd_hda_codec_generic,snd_hda_codec,snd_hda_intel,snd_seq_device
soundcore              15047  2 snd,snd_hda_codec
parport_pc             32741  0
dell_smo8800           13154  0
ppdev                  17671  0
shpchp                 37047  0
mac_hid                13227  0
lp                     17759  0
parport                42348  3 lp,ppdev,parport_pc
hid_generic            12559  0
usbhid                 52616  0
hid                   110426  2 hid_generic,usbhid
nouveau              1210720  4
mxm_wmi                13021  1 nouveau
psmouse               106767  0
i2c_algo_bit           13413  1 nouveau
ahci                   34142  4
wmi                    19193  3 dell_wmi,mxm_wmi,nouveau
sdhci_pci              23301  0
ttm                    93588  1 nouveau
firewire_ohci          40551  0
libahci                32424  1 ahci
drm_kms_helper         61574  1 nouveau
e1000e                226396  0
sdhci                  43693  1 sdhci_pci
drm                   311061  7 ttm,drm_kms_helper,nouveau
firewire_core          68769  1 firewire_ohci
crc_itu_t              12707  1 firewire_core
ptp                    19395  1 e1000e
pps_core               19382  1 ptp
video                  20128  1 nouveau
Is there a quick reference you can point me to for blacklisting that sucker? What is it that's grabbing the device? Mirics?
thank you again I feel I am getting close. I don't think I have ever compiled so much software in one sitting as I did yesterday. :?
Postby sdrplay » Fri Mar 18, 2016 4:17 pm
temporarily you can use sudo rmmod <mod name>, it will allow you to test if you are removing the right mod but it doesn't survive a reboot.
On ubuntu I've edited the file /etc/modprobe.d/blacklist.conf and added
blacklist sdr_msi3101
which is permanent
WCat
Postby WCat » Fri Mar 18, 2016 4:22 pm
Yes I manged to rid myself of the libusb warning.
$ SoapySDRUtil --probe=sdrplay
mir_sdr_2500_Init: fnaddr = 4
setToggleStates: initialising sampNum=0x0001f802, gainSetting=0x210, FsToggle=0, RfToggle=1, GrToggle=1
  driver=SDRPlay
  hardware=SDRPlay
  Timestamps: NO
  Other Settings:
-- RX Channel 0
  Full-duplex: YES
  Supports AGC: NO
  Antennas: RX
Have not had much time to mess with it though I still am just receiving cosmic background in all it's glory.
Anymore help greatly appreciated
Thank you for your time and patience!
Postby sdrplay » Fri Mar 18, 2016 4:43 pm
Can you post a screenshot of CubicSDR running and an idea of what settings you selected on the device selection screen.
