Sdr-console V3 Preview is out
supwiddiss
Re: Sdr-console V3. Point andclick tuning?
Postby supwiddiss » Fri May 26, 2017 2:00 pm
In V2 (and other SDR applications) pointing on an active signal and clicking allows tuning to the center freq.
I'm using an RSP2 with Sdr-console V3 and cannot use the touch pad on an ASUS laptop to click and tune.
Any suggestions? I've searched settings and so far, no joy.
Thanks!
Re: Sdr-console V3 Preview is out
Postby g1hbe » Fri May 26, 2017 2:50 pm
Please forgive me if I'm misunderstanding you, but why would you want to place a frequency (the one you want to listen to presumably?) at centre? With the SRP units (and any other 'zero IF' SDR) that's where the central DC spike is and should be avoided.
supwiddiss
Postby supwiddiss » Tue Oct 10, 2017 10:07 pm
g1hbe wrote:Please forgive me if I'm misunderstanding you, but why would you want to place a frequency (the one you want to listen to presumably?) at centre? With the SRP units (and any other 'zero IF' SDR) that's where the central DC spike is and should be avoided.
Clarifying a bit. Clicking ON the frequency to listen to has not worked.
Touchpad "gestures" to tune and/or simple right or left mouse clicks to tune up/down (as in HDSDR).
The developer flat out told me to forget implementation of those things by him.
Scanning/storing search ranges will never happen.
I'm currently using SDR# 1361 with the plugins needed to do what even a cheap table top or expensive professional receiver already has built in.
I will abandon Simon's software for the time being. It's been quite awhile since I have launched it.
Users browsing this forum: Sasan and 5 guests
