ubuntu 16.04: nothing works!
Re: ubuntu 16.04: nothing works!
Post by sdrplay » Wed Jul 20, 2016 9:22 pm
The author of SoapySDR got back to me, can you try the 0.4 build of SoapySDR/SoapySDRPlay just to rule that out...
cd SoapySDR && git checkout soapy-sdr-0.4.4
then build + install SoapySDR and relevant modules
AH6DL
Post by AH6DL » Thu Jul 21, 2016 6:57 am
I had a long day at work and didn't have a chance to try SoapySDR v4, but I can report the results of the tests you mention match yours except that the mirsdrapi is in /usr/lib instead of /usr/local/lib. I also have the 32 bit version of libusb installed as part of my multilib configuration along with the 64 bit version.
[dl@t520 ~]$ ls -l /usr/lib/libusb-1.0.so.0.1.0
-rwxr-xr-x 1 root root 101296 Oct  9  2015 /usr/lib/libusb-1.0.so.0.1.0
[dl@t520 ~]$ ldconfig -p | grep libusb
        libusbmuxd.so.4 (libc6,x86-64) => /usr/lib/libusbmuxd.so.4
        libusbmuxd.so (libc6,x86-64) => /usr/lib/libusbmuxd.so
        libusb-1.0.so.0 (libc6,x86-64) => /usr/lib/libusb-1.0.so.0
        libusb-1.0.so.0 (libc6) => /usr/lib32/libusb-1.0.so.0
        libusb-1.0.so (libc6,x86-64) => /usr/lib/libusb-1.0.so
        libusb-1.0.so (libc6) => /usr/lib32/libusb-1.0.so
        libusb-0.1.so.4 (libc6,x86-64) => /usr/lib/libusb-0.1.so.4
[dl@t520 ~]$ ldconfig -p | grep mirsdrapi
        libmirsdrapi-rsp.so.1.95 (libc6,x86-64) => /usr/lib/libmirsdrapi-rsp.so.1.95
        libmirsdrapi-rsp.so (libc6,x86-64) => /usr/lib/libmirsdrapi-rsp.so
I hope to have time tomorrow night to recompile SoapySDR and see if the results are different. Note that everything works using a USB 3.0 port and USB 2.0 works with the gqrx, but not with dump1090_sdrplus and CubicSDR.
73...
. ...Doug, AH6DL
IW2DHW
Post by IW2DHW » Thu Jul 21, 2016 7:33 am
This is my last test before starting for my vacation.
Checked 0.4.4 version of SoapySDR
Removed any previous version, also build directory
Compiled and installed 0.4.4 version
Removed any previous version of SoapySDRPlay and SoapyRTLSDR, also build directory
Compiled and installed SoapySDRPlay, SoapyRTLSDR and CubicSDR
Now ldd show a 0.4.4 requirement for SoapySDR library for Cubic
SoapySDRUtil --info
show correct version
ShowSDRUtil --probe have same error (show 2 RTLSDR devices!)
After removing RTLSDR device CubucSDR and my test python program crash, as usual, Ubuntu 16.04
After my vacation I will install a fresh version of Ubuntu 16.04 (no upgrade) and test it
Regards
Franco Spinelli
IW2DHW
Post by sdrplay » Thu Jul 21, 2016 8:16 am
Hi Doug,
I'm confused as to how the mirsdrapi stuff ended up in /usr/lib?
It's not in /usr/local/lib at all?
Do you have a /usr/local directory? Have you tried the export LD_LIBRARYPATH= /usr/lib or /usr/local/lib if you have libraries in there?
Post by sdrplay » Thu Jul 21, 2016 8:18 am
Doug,
Could I get remote access to the machine (TeamViewer maybe?) - I'd just like to understand how your system differs.
If so, drop me an email at software@sdrplay.com with the login details and an appropriate time.
AH6DL
Post by AH6DL » Fri Jul 22, 2016 1:40 am
I had a chance to uninstall SoapySDR and CubicSDR and rebuilt both using the SoapySDR v0.4.4-gdb459f4f release. I also deleted and rebuild the SoapySDRPlay module.
Unfortunately, the behavior is the same as before. The messages are the same, although I did note that it printed "SDR enumerator done" , not "made" as I'd written down on the last crash test.
libusb is built from http://downloads.sourceforge.net/libusb-1.0.20.tar.bz2
source file md5sum = 1d4eb194eaaa2bcfbba28102768c7dbf
Also, as before, everything works great using a USB 3.0 port.
73...
...Doug, AH6DL
rtrn
Post by rtrn » Sun Jul 24, 2016 6:14 am
ubuntu 16.04 and USB 2.0 64 bit
SDRPlay API 1.95.3
mir_sdr_SetTransferMode(mir_sdr_ISOCH) does not work, system crash
mir_sdr_SetTransferMode(mir_sdr_BULK) working
Regards
AH6DL
Post by AH6DL » Wed Jul 27, 2016 4:20 pm
I can confirm adding:
mir_sdr_SetTransferMode(mir_sdr_BULK);
above all mir_sdr_Init statements in the source code stops the crash using USB 2.0.
For SoapySDRPlay I had to edit Registation.cpp and Streaming.cpp.
dump1090_sdrplus now works after modifying dump1090.c .
Glad to see we got this fixed!
73...
...Doug AH6DL
bilbolodz
Post by bilbolodz » Mon Aug 01, 2016 6:00 pm
Merge into source no github
bilbolodz
Post by bilbolodz » Mon Aug 01, 2016 6:01 pm
Proposed changes merged into source on github
