How to use simultaneously multiple SDRPlay modules?
Dear all,
I plan to test signal processing algorithms for passive radar applications using DVB-T waveforms based on multiple SDRplay modules.
For that, I need to record (almost simultaneously) the raw IQ streams from several SDRPlay modules (a couple would be nice, more would be great). I actually use the MIRICS API through a play_sdr like C code. It works fine with one module but it seems that mir_sdr_usb_USB fails when two modules are plugged.
Any suggestion?
Regards,
Gilles.
Any suggestion?
Regards,
Gilles.
Re: How to use simultaneously multiple SDRPlay modules?
On Windows this is already possible. I have 3 running at the same time.
In the next release of the API for non-Windows platforms you will be able to run more than one RSP at the same time.
We're working hard to get this released soon.
Many thanks for your response,
I work with Arch Linux (Manjaro). I look forward this new release for the API.
Let me know, please, when it is available.
Gilles.
Gilles.
