GNUradio
signon
GNUradio
Post by signon » Thu Aug 04, 2016 2:02 pm
Hello!
Can you tell me how can I install gnuradio compatible with SDRplay?
SIGNON
DK7OB
Re: GNUradio
Post by DK7OB » Fri Aug 05, 2016 10:26 am
There is no direct support for SDRPlay in gnuradio. You need gr-osmosdr. You can go 2 ways:
1. Direct SDRPlay support in gr-osmosdr: You have to build gr-osmosdr from source and enable the NON_FREE drivers. Not recommended, since the SDRPlay support in gr-osmosdr is rather incomplete and there seems to be no development activity.
2. Indirect support via soapysdr. This uses the soapysdr driver in gr-osmosdr and requires soapysdr and soapysdrplay to be installed. I think you get this when you install the SDRPlay API driver. I would recommend this way.
But also here the SDRPlay support is far from complete. So I have my own modified versions of gr-osmosdr and sopysdr/soapysdrplay with a number of modifications which make it quite usable with gqrx (which is based on gnuradio).#
Wolf DK7OB
