dump1090 and RSP2 notch filters
I live close to a very strong FM station. I normally use the RSP2 notch filters to prevent interferences. I would like to activate these filters when using dump1090 but it seems there is no option to activate them. Thus I have to use an inline FM filter with the RSP2 which is a bit weird.
Am I right and there is not option? If yes, are there plans to implement this switch ? (the github repository does not show much activity...)
Best
Best
Re: dump1090 and RSP2 notch filters
Hi
There is no way that a software filter could be of any use on a signal outside
the maximum 10 MHz bandwidth of the RSP.
And even when it is useful it uses a lot of dynamic range and processing power.
To protect from 100MHz when receiving 1GHz a shorted IGHz quarter wave line
connected with a T adapter on the input is a good start.
I find myself disoriented after reading your response. The AM/FM BC notch filter of the RSP2 is software-selectable but I though it was an 'actual' filter, not a 'software filter' (DSP filter ?)... The RSP2 FM filter is specified as providing >60dB on the range 80 – 100MHz. So I understood it is used to eliminate images outside this band...
It is a hardware filter on the RSP2 that is software selectable and it is enabled in the RSP2 version of dump1090
You are quite right my answer doesn't apply in that case.EA3HUF wrote:I find myself disoriented after reading your response. The AM/FM BC notch filter of the RSP2 is software-selectable but I though it was an 'actual' filter, not a 'software filter' (DSP filter ?)... The RSP2 FM filter is specified as providing >60dB on the range 80 – 100MHz. So I understood it is used to eliminate images outside this band...
Thanks, understood.sdrplay wrote:It is a hardware filter on the RSP2 that is software selectable and it is enabled in the RSP2 version of dump1090
Joaquin
