Using SDR Console.
M0DEP
Re: Using SDR Console.
Postby M0DEP » Sat May 30, 2015 12:27 am
Hi Paul,
Thanks for the info. Yeah any updates would be much appreciated. As far as PPM goes, mine is fine as well at least for voice, however I was experimenting last year with an RTL dongle with modded temp controlled TCXO using the dongle as my receiver and my FT-847 as the transmitter to do digital modes, so for me matching the dongle exactly to my radio is critical. The Same will be required when I try it again with the SDRplay as digital signals are very narrow and a few hertz off frequency can make a big difference compared with voice. Just for your info, I was doing this using an ELAD switch box (RX/TX Automatic exchanger) which basically Isolates the SDR when you transmit (both RF and AF) and in conjunction with Cat cable and Omni rig makes a great combination. Its awesome to see a signal in the waterfall, click it and then work it. No dial turning required :)
Anyway I digress and way past bedtime
Keep us posted on any info Paul
Russ (M0DEP)
ON4LL
Postby ON4LL » Thu Jun 11, 2015 4:45 pm
Ohhh
lucky I've read this ... I was wondering why I needed to start and stop all the time.
Hope Simon is doing an update for this, happy to donate if it works :-)
jon
Postby jon » Tue Jul 07, 2015 7:59 pm
Our friend Simon Brown updated SDR-Console yesterday and again today. The latest version includes lots of improvements for SDRplay. The details of these (version 2.3 beta build 2171) are listed on http://sdr-radio.com/Radios/SDRPlay and the software can be downloaded from
http://sdr-radio.com/Software/Download/Download-Kits
zanco
Postby zanco » Sat Jul 18, 2015 12:47 pm
After installing the latest build ( 2178 ) does one still have to install the EXTIO installer into this folder or is that necessary for SDR# and HDSDR ?
Ben - PE2BZ
mikexeno
Postby mikexeno » Tue Jul 21, 2015 5:15 am
The ext/io is for hdsdr and sdr# and any other front end that supports the ext/io. Sdr-console does not use this
jimcking2
Postby jimcking2 » Tue Sep 15, 2015 6:41 pm
I am still having the same problems mentioned hear even with the SDR Console V2.3 2194. Is it working for other people?
Jim K.
jon
Postby jon » Tue Sep 15, 2015 9:20 pm
We at Sdrplay have a call booked this week with Simon Brown at SDR Console to get the latest API working I.e. Removing the gap and allowing tuning across band edges.
