Unable to select Hi Z antenna port
Posted: Sun Jan 01, 2017 8:31 pm
by Mwarpenburg
I have a brand new RSP2 that is otherwise working fine. I am using the latest SDRuno.
I am unable to select the Hi Z antenna port. When attempted the software (as represented on the UI) simply jumps to ANT A.
I have tried restarting and most of the obvious things. I am able to select ANT A or ANT B without problems.
Any support or workaround would be much appreciated.
-Mike
Re: Unable to select Hi Z antenna port
Posted: Sun Jan 01, 2017 11:56 pm
by Mwarpenburg
BTW... below is a link that demonstrates the problem. It takes you to a video in my DropBox. Thanks.
http://www.dropbox.com/s/sgvgihfrm6b51q ... m.mp4?dl=0
Posted: Mon Jan 02, 2017 8:57 am
by sdrplay
You only show the Main Window so we can't see what frequency you are tuned to. If you are at 30MHz or above this behaviour is correct as the HiZ port is only specified from 1kHz to 30MHz
Posted: Mon Jan 02, 2017 3:34 pm
by Mwarpenburg
Makes sense. I was probably tuned to that frequency and not thinking about it at the time. The DSP engine was stopped at the time. Perhaps a friendly reminder message would be in order... but, my bad.
Thanks very much for the support. You guys are rock stars. I see great things ahead for your company. The "high end" SDR radio companies have to see the writing on the wall. Price competition pressure is going to be coming on strong in the next 4-5 years. SDRuno has a way to go, of course, but it was a brilliant acquisition; it is really going to give you a jump start.
I would love to be a beta tester. I am a retired electrical engineer and programmer with more years of experience than I like to think about. I've coded on more systems & languages than I can remember from microcode all the way to C, C++, C#, Java... LISP & AI. Haha... please don't blame me for AI.
Anyway... what an exciting thing to be part of!
Very best regards,
Mike
