Sdrsharp pluggin
kevtheskin
Sdrsharp pluggin
Postby kevtheskin » Fri Jan 13, 2017 12:52 pm
Hi everyone,
I am trying to install the Sdrsharp plugin version2.2. It keeps bring up an error setup has detected a problem with this Sdrsharp install.
Any ideas.
Cheers Kev
Re: Sdrsharp pluggin
Postby sdrplay » Tue Jan 17, 2017 8:26 am
During the install of the plugin, it will require you to navigate to your SDR# installation directory and select the SDRSharp.exe before continuing.
Please note that this is only for SDR# version greater than 1411 and will only provide basic tuning for the RSP1. The RSP2 is not supported. You will also need an old version of the API which you can get here if you don't have it: http://www.sdrplay.com/software/MiricsS ... r_1.97.exe
JMG
Postby JMG » Tue Jan 17, 2017 7:59 pm
Works fine with SDRsharper(v0.5k) too.
ic706mk2
Postby ic706mk2 » Wed Jan 18, 2017 10:09 am
Hey,
@Jmg..
Don't work by me..what did you do..only the old api or must we do something else also?
Change the Sharper.exe to Sharp.exe???
SDRSharp much better to works with .
Greetings
Luc
supwiddiss
Postby supwiddiss » Tue May 09, 2017 11:23 pm
New to this. A day into my RSP2pro. Due to the amount of plugins for # it was my assumption that the RSP2 would be a breeze to get working with it.
No Joy!
HDSDR and SDRConsole seem limited for plugins also, Hence it looks like I have a simple radio receiver and need to use VAC/VB Cable to pipe into the other applications that I accepted would seamlessly work with the RSP2.
Any and all comments are welcome. I am an EE with tons of years using HAM equipment and anything electronic that is fun.
Cheers.
