Web Interface not working dump1090
thansen
Postby thansen » Fri Feb 03, 2017 8:30 pm
As the subject says, I can't get the Web Interface for sdrplay_dump1090 to work.
I am using RSP1 and the software installed on an Raspberry Pi 3, feeding both Flightaware and FR24, everything working fine except for the Web Interface.
I have installed Virtual Radar on my Windows PC, but would very much like to get the Web Interface working so I can connect to this instead, and install some additional software for statistics and access this from the Web Interface.
The IP for the system i 192.168.1.50, and when I try to connect to 192.168.1.50:8080 I get "Error opening HTML file: No such file or directory"
The default port is 8080, i have tried changing the port to 8090 with --net-http-port 8090, but gets the same result, The port change however works, I can see this when trying to connect to port 8080 when using --net-http-port 8090 i'll get "ERR_CONNECTION_REFUSED" instead of "Error opening HTML file: No such file or directory".
Anybody knows why the Web Interface doesn't work with the sdrplay_dump1090 and can help me get it working?
Thank you.
thansen
Re: Web Interface not working dump1090
Postby thansen » Sat Feb 04, 2017 11:33 am
Just made some tests.
The OS is Raspbian Jessie Lite, I thought it could be because of the Lite version, maybe some packages where missing, so I installed the full version of Raspbian Jessie on a spare RPi3 and another RSP1, but no luck, still the same.
deadite66
Postby deadite66 » Thu Apr 20, 2017 6:22 pm
Had the same problem, found out you can run Modesmixer on the pi to get around this problem.
http://xdeco.org/?page_id=48
./modesmixer2 --inConnect 127.0.0.1:30002 --web 8888
and now i can see the planes on a web page on 127.0.0.1:8888
no map though due to google.
RSP2 Pro and RSP1A owner.
alleyoop
Postby alleyoop » Sat Apr 22, 2017 6:25 pm
I'm not even getting that far with an RSP2 on the latest Jessie image.
Dump1090 wil stop after a few seconds with 'Unable to initialize RSP', will the USB-ports on the RPi3 deliver sufficient current for the RSP2?
deadite66
Postby deadite66 » Sat Apr 22, 2017 9:25 pm
by default the usb power is reduced in raspbian.
on the boot partition there is a config.txt file.
if you add
max_usb_current=1
it will unlock the full power, but have a good power supply.
alleyoop
Postby alleyoop » Sun Apr 23, 2017 6:40 am
Thanks for the hint but the problem persists.
When listing the USB devices with lsusb my RSP2 is shown with ID 1DF7:3010 but it's not followed by the vendor and device type so I guess it's not enumerated correctly.
deadite66
Postby deadite66 » Sun Apr 23, 2017 8:44 am
it does that for me too.
only "Bus 003 Device 011: ID 1df7:3010" displayed.
what psu are you using, running my rpi3 off a 2amp usb brick.
alleyoop
Postby alleyoop » Sun Apr 23, 2017 11:32 am
I'm using a 1.8A power supply but I obtain the same result with a 3A PSU and even a 1A Cell Phone PSU.
I'm measuring 4.6-4.7V directly on the PCB of the RSP2 when feeded through the Pi whereas a direct USB connection with my pc will yield 5V.
I have already changed the USB cables by shorter ones but alas to no avail...
Maybe a powered USB-hub will solve my problems...
EA3HUF
Postby EA3HUF » Mon Aug 21, 2017 11:03 am
I am getting the same problem.
VRS works perfect, but I cannot connect to the sdrplay_dump1090 http server from a local computer.
There is something new about this problem?
Someone fixed it ?
I am using a raspi3 and a RSP2 with the more recent API and sdrplay_dump1090 packages from the download page of the SDRPlay website.
One year ago, using the dump1090_sdrplus package in the same raspi3 and with a RSP1 I was able to connect to the HTTP server (on localhost) and to see the planes (triangles) on google maps.
I have not tried localhost:8080 this time because I have the raspi without screen, controlled by SSH, but address2pi:8080 from a local computer should work. However, I get
Postby sdrplay » Mon Aug 21, 2017 11:45 am
It's probably because public_html directory isn't present from where you are running dump1090 from. You could try getting the contents from here:
https://github.com/SDRplay/dump1090/tre ... ublic_html
And trying again
Best regards
SDRplay support
Users browsing this forum: Bing [Bot] and 4 guests
