Rsp2 - does it have a "stand-by" mode?
Posted: Sun Feb 05, 2017 12:27 am
by zardoz99
Does anyone know if the RSP2 has any form of low-power or stand-by mode when it is not actively being used by an application? If so, which components are "shutdown"?
Re: Rsp2 - does it have a "stand-by" mode?
Posted: Sun Feb 05, 2017 5:04 pm
by Tod Yampel
Use the Start/Stop button on the SP Main screen.
You will notice the CPU utilization go down as displayed by Sys value on the same screen.
Good luck
73 KD2JNF
Posted: Sun Feb 05, 2017 8:36 pm
by zardoz99
I'm more interested in if it is allowed to cool down or something. My RSP2Pro was sitting with USB power available overnight but the PC shut down. When I fired it up to check out the signal reception at 1090, prior to starting dump1090, the signals appeared to be coming in somewhat below the expected location. Over a couple of minutes, they appeared to stabilize at the correct frequency, as if the RSP2Pro was warming up... Hence the question...
