RSP2 not recognized on raspberry pi
Posted: Fri May 26, 2017 1:50 pm
by hb9txb
Hello
My RSP2 receiver is not recognized by raspi:
lsusb shows
pi@raspberrypi:~ $ lsusb
Bus 001 Device 005: ID 1df7:3010
Bus 001 Device 004: ID 7392:7811 Edimax Technology Co., Ltd EW-7811Un 802.11n Wireless Adapter [Realtek RTL8188CUS]
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
pi@raspberrypi:~ $ sudo sdrplay_dump1090 --dev-sdrplay --quiet
Thu May 25 08:51:01 2017 CEST dump1090-mutability dump1090_mutability_sdrplay starting up.
Using sample converter: SC16, integer path
Unable to initialize RSP
Thu May 25 08:51:04 2017 CEST Normal exit.
http://www.raspberrypi-spy.co.uk/2012/0 ... d-version/
Revision : 0010
Already tried to set
#max power for usb
max_usb_current=1
Also tried different power supply, additional power for RSP2 using Y-cable
Terratec RTL dongle and RTL SDR v3 dongle work fine
RSP2 works when attached to my Mac
Please advise
Re: RSP2 not recognized on raspberry pi
Posted: Sun May 28, 2017 1:10 am
by navzptc
Download the newer 0.2 version - 0.1 did the same with my set up, but 0.2 works fine :)
Posted: Fri Jun 02, 2017 5:35 pm
by hb9txb
Thanks. SDRplay download offers only ver 0.1
ver 0.2 is at www.sdrplay.com/software/SDRplay_ADS-B_RPi_0.2.run
In the meantime Cocoa1090 is expired ...
