SoapySDRPlay compile error on Unbuntu 14
src1138
Re: SoapySDRPlay compile error on Unbuntu 14
Postby src1138 » Thu Jul 27, 2017 4:32 pm
I downloaded the 64 bit api from the sdrplay website.
The api install appears to work ok.
Steve
src1138
Postby src1138 » Thu Jul 27, 2017 4:37 pm
SDRplay_RSP_API-ARM64-2.10.1.run
Postby Tech_Support » Thu Jul 27, 2017 4:44 pm
This is for ARM 64 bit machines. You need the x86 version of the API/Driver as you are using an x86 processor, which is available via the Linux x86 tab.
src1138
Postby src1138 » Fri Jul 28, 2017 1:14 pm
That worked - I was using the wrong driver :roll:
Thank you for the support.
Steve
