RSP1 on ubuntu 17.04
9a4db
Postby 9a4db » Fri Jul 07, 2017 8:22 am
q@q-X756UX:~$ SoapySDRUtil --check=sdrplay
Loading modules... done
Checking driver 'sdrplay'... PRESENT
q@q-X756UX:~$ SoapySDRUtil --probe=sdrplay
Probe device sdrplay
fwDownload: FW image size = 6008
mir_sdr_usb_GetDevices Dev0:vid=1df7 pid=2500 rev=0206 serno=B0001P0003 bus=001 port=003 devAvail=0
[INFO] Make connection: ''
Error probing device: Failed to make connection with ''
q@q-X756UX:~$
Lime SDR and RTL-SDR v2 working ok.... any tips?
Yes I have reinstalled couple of times....
73
Re: RSP1 on ubuntu 17.04
Postby sdrplay » Sun Jul 09, 2017 6:50 pm
devAvail=0 probably means you need to blacklist the kernel drivers....
edit /etc/modprobe.d/blacklist.conf
add..
blacklist sdr_msi3101
blacklist msi001
blacklist msi2500
Then save the file and reboot. Try the SoapySDRUtil again.
9a4db
Postby 9a4db » Sun Jul 09, 2017 8:55 pm
Yes, thank you.... later made add to black list
Now ->
q@q-X756UX:~$ SoapySDRUtil --info
Lib Version: v0.6.0-g2f6a449e
API Version: v0.6.0
ABI Version: v0.6
Install root: /usr/local
Search path: /usr/local/lib/SoapySDR/modules0.6
Module found: /usr/local/lib/SoapySDR/modules0.6/libLMS7Support.so
Module found: /usr/local/lib/SoapySDR/modules0.6/libremoteSupport.so
Module found: /usr/local/lib/SoapySDR/modules0.6/librtlsdrSupport.so
Module found: /usr/local/lib/SoapySDR/modules0.6/libsdrPlaySupport.so
Available factories...lime, null, remote, rtlsdr, sdrplay,
q@q-X756UX:~$ SoapySDRUtil --find=sdrplay
mir_sdr_usb_GetDevices Dev0:vid=1df7 pid=2500 rev=0206 serno=B0001P0004 bus=001 port=004 devAvail=1
Found device 0
driver = sdrplay
label = SDRplay Dev0 RSP1 B0001P0004
q@q-X756UX:~$
While CubicSDR and GQRX are able to recognize SDRPlay - run is impossible.
Any other tips?
Postby sdrplay » Mon Jul 10, 2017 5:55 am
Not sure what you mean by run is impossible. In CubicSDR, you select the device and parameters and press start. That doesn't work for you?
There is an issue with > 2.5MHz sample rate on Linux which I'll be pushing an update for this week but if you stick to defaults it should work ok.
Have you also tried... SoapySDRUtil --probe=sdrplay
9a4db
Postby 9a4db » Mon Jul 10, 2017 7:04 am
Here, CubicSDR, all SDR-s detected, first two working, last RSP1 detected, but not able to work....
Screenshot from 2017-07-10 08-54-16.png (35.24 KiB) Viewed 4177 times
Probe ->
mir_sdr_usb_SetDeviceIdx idx=0 numDevices=1
Opened device with idVendor = 0x1df7 idProduct = 0x2500 fwVersion = 0x0206 busNum = 001 portNum = 004
mir_sdr_Init: gR=60dB fs=2.000MHz rf=98.800MHz bw=1.536MHz if=0.000MHz
DownConvert: Enable=0 DecM=1 OutScale=0 (fs=2.000000 bw=1536 if=0)
mir_sdr_2500_Init: fnaddr = 7
initHw: Register7 = 0x000014
initRfFreqDependentHw(1): Tuner Register0 = 0x04f420
mir_sdr_SetFs: Sample Freq requested 2000000.000000
mir_sdr_SetFs: Fs->FsNomHz+dFsHz=2000000.0+0.0Hz=2000000.0Hz FsToggle->1
mir_sdr_SetRf: f->98800000.000Hz (int=20 frac=af0 afc=0) fSynth:3161600000.000
mir_sdr_SetRf: Rf->RfNomHz+dRfHz+LifHz+Lif1Hz=98800000.0+0.0+0.0Hz+0.0Hz=98800000.0Hz RfToggle->1
mir_sdr_SetGr: GR->60[36,24,0,0] gRset->0x224 DCCALmode=3 DCCALspd=0 GrToggle->1
mir_sdr_usb_StreamRead: Read failed to read sufficient data: requested 393216 read 0
mir_sdr_2500_StreamRead: Read failed
mir_sdr_usb_StreamUninit: Stream stop timeout (4000 0)
mir_sdr_2500_StreamRead: Read failed again
setToggleStates: failed mir_sdr_2500_StreamRead err=1
initHw: setToggleStates() Error 1
mir_sdr_Init: initHw returns error 7
Warning: DriverCallback() couldn't match transfer 0x55aefa543120
Warning: DriverCallback() couldn't match transfer 0x55aefa53ed00
Warning: DriverCallback() couldn't match transfer 0x55aefa52a6c0
Warning: DriverCallback() couldn't match transfer 0x55aefa52b3e0
Warning: DriverCallback() couldn't match transfer 0x55aefa52c100
Warning: DriverCallback() couldn't match transfer 0x55aefa52ce20
Warning: DriverCallback() couldn't match transfer 0x55aefa52db40
Warning: DriverCallback() couldn't match transfer 0x55aefa52e860
mir_sdr_2500_Readback001Trim: readback = 0xd1c020f
mir_sdr_2500_Bypass001Trim: reg13=0x1ed reg14=0x47002e
Trying to open device with mir_sdr_Init failed
mir_sdr_usb_SetDeviceIdx: Unable to access EEPROM
-- Device identification
driver=SDRplay
hardware=1 B0001P0004
mir_sdr_api_version=2.100000
mir_sdr_hw_version=1
-- Peripheral summary
Channels: 1 Rx, 0 Tx
Timestamps: NO
Other Settings:
[key=rfgain_sel, default=1, type=string, options=(0, 1, 2, 3)]
-- RX Channel 0
Full-duplex: YES
Supports AGC: YES
Stream formats: CS16, CF32
Antennas: RX
Corrections: DC removal
Full gain range: [0, 39] dB
IFGR gain range: [20, 59] dB
CORR freq range: MHz
Sample rates: 0.25, 0.5, 1, 2, 2.048, 6, 7, 8, 9, 10 MSps
Filter bandwidths: 0.2, 0.3, 0.6, 1.536, 5, 6, 7, 8 MHz
mir_sdr_usb_ReleaseDeviceIdx 0
q@q-X756UX:~$
On other PC under win10 all is in order. Before on ubuntu 16.04 ok too.
Best Regards
Djani
Postby sdrplay » Mon Jul 10, 2017 6:32 pm
Are you using USB 3.0 port? Make sure it's a USB 2.0 port or an external mains powered USB 2.0 hub.
If you are using USB 2.0 and you've tried different USB cables you may need the updated driver I will be sending out.
Contact me on software@sdrplay.com if you want to beta test it.
Can you let me know what processor you have and what API download you did?
9a4db
Postby 9a4db » Tue Jul 11, 2017 10:59 am
Thank you
Yes I am using USB 2.0 port, on the same port Lime reporting USB 2.0 and working on low bandwith, RTL-SDR v2 stick too
API -> SDRplay_RSP_API-Linux-2.10.1.run
Guess no need to test another USB cable because the same RSP1 setup is working on Win10 machine using CubicSDR or SDRConsole V3
CPU here
Screenshot from 2017-07-11 12-52-43.png (25.43 KiB) Viewed 4121 times
Email sent regarding beta driver...
Regards
Djani
9a4db
Postby 9a4db » Wed Jul 12, 2017 1:07 pm
Problem solved with beta driver....
CubicSDR working now
SDRAngel some further work needed (on Angel compilation side)
Thank you for prompt assistance
Regards
Djani
jbirdlebough@msn.com
Postby jbirdlebough@msn.com » Wed Sep 20, 2017 5:51 pm
Cheers I need help, I have successfully built CubicSDR on a Orange Pi 2+ running armbian version of ubuntu 16.04, on armf platform. I have also recompiled the OS to enable SPI, i2C, and all USB devices (1,2,3). from Os lsusb shows SDRPlay device. So at OS level we at least see the device.
I also have RPi 3, I used the image that worked.
But I can't find source I can build on OPi2+ platform to rebuild the API SDRPlay driver.
Can anyone help me. OPI has 2GB ram, 16GB emmc(internal nand) and is much faster than RPi 3, so I am trying to get this working.
Thanks for any help you can provide.
jbirdlebough@msn.com 8-)
Last edited by jbirdlebough@msn.com on Thu Jan 01, 1970 12:00 am, edited 0 times in total.
Postby sdrplay » Thu Sep 21, 2017 5:43 am
We do not provide the source for the API. I would suggest trying the Raspberry Pi API or the ARM64 API if it's a 64bit ARM processor. You can find both of these on our downloads page (http://www.sdrplay.com/downloads)
Let us know how you get on with those versions. If you are still struggling let us know and we'll try to help.
