Problem with current RSP1 ExtIO and API
n2ic
Postby n2ic » Mon Jul 31, 2017 4:34 pm
I am the software developer for a popular ham radio program called Waterfall Bandmap.
I recently installed the current RSP1 ExtIO and API on Windows 7. I am seeing a problem if I initially select the RSP1 ExtIO (but don't call StartHW), then select a different (non-RSP) ExtIO, then reselect the RSP1 ExtIO. Reselecting the RSP1 ExtIO gives the "Failed to find any RSP1's" message. The sequence of ExtIO calls I am making is:
1st selection of RSP1 ExtIO:
InitHW
OpenHW
Select other ExtIO (or sound card):
CloseHW
Reselect RSP1 ExtIO:
InitHW
This causes the "Failed to find..." message.
If I close my Waterfall Bandmap application, and restart it, I can, again, initially select the RSP1 ExtIO.
Is the CloseHW call failing to fully close the RSP1, or is there another ExtIO call I should be making ?
Thanks !
Steve
Re: Problem with current RSP1 ExtIO and API
Postby sdrplay » Tue Aug 01, 2017 1:55 am
It looks like CloseHW isn't releasing the device (which is required before reacquiring it again). If you contact software@sdrplay.com I can work with you on that to resolve the issue.
