What is the actual minimum sample rate of ADC
jazzkutya
Postby jazzkutya » Fri Sep 25, 2015 1:56 pm
Hi All,
What is the actual minimum sample rate of the ADC, without any DSP or host software processing? What analogue IF filtes are usable before the ADC?
jazzkutya
Re: What is the actual minimum sample rate of ADC
Postby Tech_Support » Fri Sep 25, 2015 3:02 pm
Dear Jazzkutya,
The minimum ADC sample rate without sample rate conversion in software is approximately 2.5 MS/s. The available IF bandwidths of the device (double sided) are:
ZIF mode
200 KHz
300 KHz
600 KHz
1.536 MHz
5 MHz
6 MHz
7 MHz
8 MHz
Low IF mode
200 KHz
300 KHz
600 KHz
1.536 MHz
