SDRPlay device isn't recognised
Posted: Tue Sep 29, 2015 10:14 am
I'm attempting to use my new SDRPlay in GnuRadio and when I hit the "Run" button the following appears in the message area...
Using Volk machine: sse4_2_64
gr-osmosdr 0.1.4 (0.1.4) gnuradio 3.7.7.1
built-in source types: file fcd rtl rtl_tcp uhd hackrf bladerf rfspace
FATAL: No supported devices found to pick from.
Trying to fill up 1 missing channel(s) with null source(s).
This is being done to prevent the application from crashing
due to gnuradio bug #528.
lsusb shows...
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 009: ID 1df7:2500
Bus 003 Device 002: ID 0781:5571 SanDisk Corp. Cruzer Fit
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
It doesn't look like there's a driver assigned for this device.
My /etc/udev/rules.d/66-mirics.rules file looks like this...
SUBSYSTEM=="usb",ENV{DEVTYPE}=="usb_device",ATTRS{idVendor}=="1df7",ATTRS{idProduct}=="2500",MODE:="0666"
I have followed the installation notes to the best of my understanding, so I'm a bit stumped.
The hardware itself is fine because it works like a champ in Windows & HDSDR.
Can someone help me to resolve this please?
lsusb shows...
