Linux SoapySDR cannot find sdrplay modules
Arch Linux - SoapySDR cannot find sdrplay modules.
Press y and RETURN to accept the license agreement and continue with
the installation, or press n and RETURN to exit the installer [y/n] y
Architecture: x86_64
API Version: 2.11
Remove old libraries...
Install /usr/local/lib/libmirsdrapi-rsp.so.2.11
Remove old header files...
Install /usr/local/include/mirsdrapi-rsp.h
Udev rules directory found, adding rules...
Libusb found, continuing...
Finished.
[djringjr@n1ea-laptop Downloads]$ SoapySDRUtil --find=sdrplay
[ERROR] SoapySDR::loadModule(/usr/lib/SoapySDR/modules0.7/libsdrPlaySupport.so)
dlopen() failed: libmirsdrapi-rsp.so.2.11: cannot open shared object file: No such file or directory
[ERROR] SoapySDR::loadModule(/usr/local/lib/SoapySDR/modules0.7/libsdrPlaySupport.so)
No devices found!
l am using libusb 1.0.19-1 the regular version for my Linux is 1.0.21-2.
Can anyone be of help?
djringjr
API Version: 2.11
Finished.
No devices found!
djringjr
Re: Linux SoapySDR cannot find sdrplay modules
Try this...
export LD_LIBRARY_PATH=/usr/local/lib
and then run SoapySDRUtil again.
After running the command you supplied I get:
Found device 0
driver = sdrplay
label = SDRplay Dev0 RSP2 1710072010
Also when I was downloading the drivers, I reached a screen asking me the serial number of my device and it presented me with a list of choices, none of which were even close to the serial number on my box.
The serial number sticker came off so I stuck it back on with tape.
In any event this was the file I installed:
SDRplay_RSP_API-Linux-2.11.1
Thanks for helping but something is still wrong.
David djringjr
Found device 0
driver = sdrplay
David djringjr
I also downgraded lib32-liblsb.
multilib/lib32-libusb 1.0.21-1 [installed: 1.0.19-1]
So now libusb and lib32-libusb are both 1.0.19-1 and no longer 1.0.21-1.
I get the same results.
Found device 0
driver = sdrplay
Found driver but no device.
The device is plugged in.
David
Found device 0
driver = sdrplay
David
I'm not sure why you think this isn't working? Looks ok for a --find output to me. Try...
SoapySDRUtil --probe=sdrplay
to get more info about your device.
$ SoapySDRUtil --probe=sdrplay
Probe device sdrplay
-- Device identification
driver=SDRplay
hardware=1710072010
mir_sdr_api_version=2.110000
mir_sdr_hw_version=2
-- Peripheral summary
Channels: 1 Rx, 0 Tx
Timestamps: NO
Other Settings:
[key=rfgain_sel, default=4, type=string, options=(0, 1, 2, 3, 4, 5, 6, 7, 8)]
* ExtRef Enable - External Reference Control
[key=extref_ctrl, default=true, type=bool]
-- RX Channel 0
Full-duplex: YES
Supports AGC: YES
Stream formats: CS16, CF32
Antennas: Antenna A, Antenna B, Hi-Z
Corrections: DC removal
Full gain range: [0, 47] dB
IFGR gain range: [20, 59] dB
RFGR gain range: [0, 8] dB
CORR freq range: MHz
Sample rates: 0.25, 0.5, 1, 2, 2.048, 6, 7, 8, 9, 10 MSps
Filter bandwidths: 0.2, 0.3, 0.6, 1.536, 5, 6, 7, 8 MHz
But when I do this:
Found device 0
driver = sdrplay
It doesn't find a device.
By the way, what is the SDR program I should be using?
I Installed CubicSDR from Arch Linux sources.
Regards,
djringjr
driver=SDRplay
hardware=1710072010
Timestamps: NO
Other Settings:
-- RX Channel 0
Full-duplex: YES
Supports AGC: YES
But when I do this:
Found device 0
driver = sdrplay
Regards,
djringjr
--probe and --find have both reported exactly what they should and the device has been found in both instances. As I said before, I'm not sure what you are seeing to make you think this isn't working?
Yes, CubicSDR works with SoapySDR devices.
Found device 0
Means that it found instance 0 (the first device) NOT that it didn't find any device. It does find the device and assigns it instance 0. I realise that this can be a bit confusing.
All is good here
All is good here
Thank you, yes, I did misunderstand that. I also tried to run cubicsdr and it would not work but I continued to follow the non-Windows Flow documeent and rebuilt wxwidgets - that was what was needed.
There are quite a few errors in that document.
One thing that would help many would be to have the flags for wxwidgets restated like this:
./configure --with-opengl --disable-shared --enable-monolithic --with-libjpeg --with-libtiff --with-libpng --with-zlib --disable-sdltest --enable-unicode --enable-display --enable-propgrid --disable-webkit --disable-webview --disable-webviewwebkit --prefix=`echo ~/Dev/wxWidgets-staticlib` CXXFLAGS="-std=c++0x"
Also there are some errors that we call tend to make like "make install" instead of "sudo make install" but this would cause a new comer to fail when it's important to have clear instructions.
I now wish I had kept track of the errors that I found - one was that when descending to the build subfolder, either the configure or make command had ./ instead of ../ or vice versa. I forget which.
Thank you for the help, it's working and now I won't have to return this excellent piece of hardware!
Regards,
David J. Ring, Jr., N1EA
Regards,
Where can I put:
so that not only commands issued from a terminal will know where to look but also when I click on CubicSDR in the graphical menu (I am running KDE).
I have the above line in my ~/.bashrc file.
There have been so many changes recently with Linux start up files I don't know where to put it for global use on startup.
Thanks again, I'm 99.999 percent there.
This answer will put me over the goal post.
Best to you,
David
Best to you,
David
