RSP2A and RPi 3 B+
steve@ecsykes.com
RSP2A and RPi 3 B+
Post by steve@ecsykes.com » Tue Mar 27, 2018 1:13 pm
I received the new Pi yesterday and installed the image with the required updates. Everything works fine. I put the Pi in a Eleduino metal case with a fan and installed heat sinks. Now what I need to know, how do I get the SoapyRemote app to run upon boot without using the X window? I want to run the receiver headless and only access it remotely.
Steve
Last edited by steve@ecsykes.com on Thu Jan 01, 1970 12:00 am, edited 0 times in total.
jrhartley
Re: RSP2A and RPi 3 B+
Post by jrhartley » Wed Mar 28, 2018 4:20 pm
Downloaded the image and my pi3 b+ is stuck at the coloured box, rasbian on the other hand boots.
Was hoping to use one of my rsps with the little beggar...
Post by sdrplay » Wed Mar 28, 2018 8:54 pm
We have an updated image in beta testing for the RPi 3B+, if you would like to take part in the beta test, please send an email to software@sdrplay.com
jrhartley
Post by jrhartley » Thu Mar 29, 2018 6:10 am
Thanks email sent re beta.
jrhartley
Post by jrhartley » Thu Mar 29, 2018 5:06 pm
Finally, it lives! On board wifi not working need to figure that out next!
Post by sdrplay » Fri Mar 30, 2018 8:33 am
run:
sudo raspi-config
the wifi isn't enabled until this is run. This is also where you can expand your file system if you have a SD card larger than 8GB
jrhartley
Post by jrhartley » Fri Mar 30, 2018 9:22 am
Nope, still no wifi (or even the adaptor wlan0), lucky I have plenty of hair or I would be bald by now!
Wifi dongle works fine, rsp1 works fine - was running the adsb stuff, had quick look at cubic but no audio - sheesh need another cable...
jrhartley
Post by jrhartley » Fri Mar 30, 2018 9:23 am
as an aside, how many posts needed before the annoying 'moderation' gets lifted???
Post by sdrplay » Fri Mar 30, 2018 9:43 am
I know it can be annoying, but if you were to see the amount of posts and accounts we have to remove, you would see that a clean forum with useful material is worth the slight delay. You should be ok now.
Post by sdrplay » Fri Mar 30, 2018 9:49 am
I'll be working on the RPi3B+ this weekend so I'll post more info with what I find. We are a very small team and appreciate your patience.
