Running 2 RSP1A's on one PC
Posted: Sun Apr 15, 2018 1:55 pm
by RichardG062
I have two RSP1A SDR radios and an HF as well as VHF/UHF antenna's. Is it possible to switch between each of the SDR radio's on one PC? I will not be running both SDR's at the same time but would just liker to switch between each RSP1A when required. Are there any special settings in SDRuno I should use and how does one switch between each radio?
Thank you
Re: Running 2 RSP1A's on one PC
Posted: Sun Apr 15, 2018 2:09 pm
by Tech_Support
Each RSP1A has a unique serial number. If you have two devices plugged into the same PC< when you start SDRuno, a device selection panel will appear and you will be able to select either device by its serial number. You can run both devices simultaneously by running two separate instances of SDRuno. I am afraid it is not possible to dynamically switch between two separate devices within a single instance of SDRuno at the moment.
Posted: Sun Apr 15, 2018 2:58 pm
by RichardG062
Thank you, after re booting the PC I now get the options box and can choose the required receiver.
Regasrds
Posted: Sun Apr 15, 2018 3:45 pm
by RichardG062
Restated PC and the SDR options box appeared - thank you. Just one idea for future development - for this option, could you rename the receivers rather than show the receiver serial number?
Thank you
Posted: Sun Apr 15, 2018 5:31 pm
by Tech_Support
We can certainly pass on the request to the development team.
