Low limit "Warning Out of Range"
Fones
Postby Fones » Thu Oct 22, 2015 11:06 am
Jon, can you remove the annoying "Warning Out of Range" dialogue box that I'm assuming is generated my the EXTIO when I go under 100 kHz. I can eventually trick HDSDR/SDR# to allow me to tune lower, but it's a bit of a fudge.
Cheers.
NN4F
Re: Low limit "Warning Out of Range"
Postby NN4F » Sat Oct 24, 2015 4:25 am
You can do a registry edit....
To do this you need to manually add the LowerFqLimit key to the registry in HKEY_CURRENT_USER\Software\SDRplay\Settings and then apply a number between 0 and 100 (in decimal). 100 would be 100kHz lower cut off, 50 50kHz and so on.
Paul -NN4F
Fones
Postby Fones » Sat Oct 24, 2015 1:11 pm
Perfect. Thank you Paul.
mwtp
Postby mwtp » Sun Oct 25, 2015 11:42 am
Hi folks,
How do you reg edit in W7.
73`s
Mark
vsboost
Postby vsboost » Mon Oct 26, 2015 8:09 am
Just click the start menu, type regedit and press enter.
Fones
Postby Fones » Mon Oct 26, 2015 1:08 pm
mwtp wrote:Hi folks,
73`s
Mark
If you have a Facebook account, you'll find a ready-made file to do the job.
https://www.facebook.com/groups/sdrplay/files/
mwtp
Postby mwtp » Mon Oct 26, 2015 2:38 pm
Thanks for the reply`s guys, will have a look when home from work.
73`s
Mark
mwtp
Postby mwtp » Mon Oct 26, 2015 10:23 pm
Loaded the file from Facebook and that did the trick, thanks again.
73`s
Mark
